limited slip diff options
Posted: 15 Sep 2007 11:10 pm
by alistairolsen
Sorry to start a new thread, I just didnt want to bump the older ones, particularly those full of rubbish.
We have already ascertained that OE 300 series diffs are rare beyond being worth any further discussion.
I believe no one as yet makes a diff to fit directly, although quaiffe would for enough cash and numbers. Personally tho Id rather a clutch type locker than an atb.
Diffs seem to be available for the 240 rear end (dana 30 diff) in both types, so what is required to fit the 240 diff? From searching threads I gather than the bolt heads on the crownwheel need to be carefully round down to gain clearance, and a chunk of the casing needs to be ground away further. Other than that, I assume the original drive flanges can be utilised in terms of length and spline count? I assume the crownwheel is of the same diameter, or if not then the diff body is so that the 300 series crownwheel can be fitted?
lets keep this one to a purely technical discussion of what is known, links to photos of it being done etc, not a discussion on the merits of different diff types, or the rarity of decent 300 rear ends, or whether an lsd is or isnt required.
Posted: 15 Sep 2007 11:15 pm
by alistairolsen
Posted: 15 Sep 2007 11:17 pm
by alistairolsen
diffs shown in casing for clearance
clutch type
http://janitor1.mysite.wanadoo-members. ... 010053.JPG
powerlock
http://janitor1.mysite.wanadoo-members. ... 010054.JPG
(which I believe to be gear style like quaife?)
Found here:
http://www.volvo300mania.com/forum-uk/v ... light=dana
Posted: 16 Sep 2007 06:28 pm
by sven360
The janitor's diff photos refer to HOR motorsport units-if that makes any difference?
Posted: 17 Sep 2007 12:22 pm
by jtbo
http://www.janiervast.com/kuvat/index.php?dir=lsd/ I had that one, but never managed to put it to car, then sold it...
It is HOR unit for 300 series.
Posted: 17 Sep 2007 12:37 pm
by alistairolsen
cheers, do the last couple of pics show a standard diff next to it?
I assume these are the now mega rare oe items?
by Tourinki
jtbo wrote:http://www.janiervast.com/kuvat/index.php?dir=lsd/ I had that one, but never managed to put it to car, then sold it...
Yes that looks familiar... Might have seen it somewhere not so long ago :)
Btw have you got any info about that.
Posted: 17 Sep 2007 04:26 pm
by jtbo
alistairolsen wrote:cheers, do the last couple of pics show a standard diff next to it?
I did not understand that other part was standard diff back then, I was so noob :oops:
But yes, I got standard diff with it too and that shows how it is different, I have seen 2 available and one of those I bought, however it might been same unit, my memory is bit rusty :P
If you see one grab it, no matter what price is, that is availability of item from my experience. If you look it you can't find it, but sometimes there might be bit of luck and someone offers one to you ;)
Unfortainely I have no more info, that unit that I had was unused afaik, also it is suspected not to be too good for hard/track use as it might wear out quite quick.
