Feeler: coilover front struts (Legs only)
Post by 340GLT »
I have a pair of front struts that have been converted to coilover legs, however are n o good if you want a lowered car, ideal for standard ride height or the rally boys. Will take 2.25" springs, need to double check to see if standard inserts fit, if not MR2 ones do. The leg has thread inserts in for my brakes but these can be drilled out again.
£100 ono
tommysb
Re: Feeler: coilover front struts (Legs only)
Post by tommysb »
Hi Adam,
If you can give me a bit more info about these I'd be interested. I guess I'd still need to source some springs for the coilover. What work would be needed to put these on a car, and how would they be better than just stiffer springs with stiffer dampers?
kaos
Post by kaos »
is this based arround the rally design adjustable suspension kit?
