Foggy's scrappage scheme - breaking 3 300s
Re: Foggy's scrappage scheme - breaking 3 300s
There'll be one on the 340, sure. Shipping to Norway might be tricky / expensive...
How's the scrapping coming along? Just so I know when to add it into the budget!
1985 B200E 360GLT Hatch
As you feigned no knowledge at the weekend, as well as everything else I have listed above loom plugs :p
I've got a few things (time-consuming to package) from another car I need to send out, plus a couple of urgent items people have asked for. Once that's done with, the stripping will commence!
That's excellent, thanks will let my daughter know.
hey have you got a upper coolant hose for a 1.4 340
thanks mat
thanks mat
Yes
It was new pretty shortly before the car came off the road 2 years ago. I dunno...£5, plus a couple for postage?
I'm in Lincoln, but I'd just stick it in the post.
lincoln is not to far from me and i need one as mines just split running without a thermo stat for now
pm your post code and ill see how far it is thanks mat
Hi, i need a idle solenoid for a 1.7 340 as mines dead. If you got a working one how much posted?
Thanks phil
Thanks phil
Hi Phil. None of the cars are 1.7s, I'm afraid.
i thought the solenoid was the same as used in a 340's Weber 32 DIR; you might want to double check the thread size and jet bore before you place it though...
Oooh...interesting point. Pass...I'm not at all sure
There's a good chance it is since Webcon only list one, or they certainly did when I needed one for the 32ICH on my Rebel a couple of years back. Standard thread, same function, one part for all Webers.
John.
Previous keeper of VND's 1989 340 GL 5 door vario.
1972 Triumph Dolomite Automatic.
