360 and 340D petrol filler hose 3413042 now available again
volvomania
Post by volvomania »
Born Built Beauties has just released the petrol filler hose for the 340 diesel (all years) and for the 360 (B200) built after 1986 (after ch 216375 to be exact).
The hose can also be used on earlier redblocks but only if the metal section between the two filler hoses is changed for the later plastic version.
The hoses can be found on the Born Built Beauties website (http://www.Born-Built-Beauties.eu).
Re: 360 and 340D petrol filler hose 3413042 now available ag
Post by macplaxton »
Petrol filler hose on a diesel?
Yes, I'm up for one of those. :D
yes, yes. I know you mean fuel filler hose. Perhaps sir is lacking in Uncle Ben's? :P
Post by Ride_on »
Must have a look at mine, I may be interested. Don't you need 2 per car?
The metal ones are dangerous, they rust through leading to petrol on your shoes during filling ups. If you have a pre-86 360 you should try and source the plastic version.
Aye, two per car as per parts book, one at either end.
Nowt dangerous with a bit of unrusty metal though. You could say the same about a metal petrol tank rusting. I remember Mk1 VW Glofs used to be good at rusting the top of the filler pipes with all the mud and rubbish that used to accumulated round them situated inside the wheel arch.
Not something I shall worry myself with, having a diesel 8)
volvomania
macplaxton wrote:Petrol filler hose on a diesel?
I knew that someone would be finding this one sm4
Post by Ride_on »
Petrol tanks are painted, but yes do become a problem eventually. The pipe rusts very quickly.
