New 1.4 radiator
New 1.4 radiator
Post by classicswede » 31 Jul 2005 03:05 pm
New radiator for 340 1.4
£60 + postage
Well worth it whil;e you have the chance.
Post by foggyjames » 01 Aug 2005 01:27 am
If you're in need, jump on this. A lot of 300s are at the age where their radiators are going, and this is a generous chunk cheaper than my 360 one was...and that was from a very cheap place (albeit a genuine Volvo one)!
Good luck Dai!
petavius
Post by petavius » 01 Aug 2005 07:27 pm
Bought one at the start of the year for £80! Bugger!
340GL 1984 B406 AJO - scrapped (sob)
340GLE 1987 E880 UUX
Post by foggyjames » 01 Aug 2005 07:44 pm
Still cheaper (just) than the 360 one :)
Post by classicswede » 01 Aug 2005 08:25 pm
If it helps it replaces
volvo part no 9031084
Post by 340GLT » 02 Aug 2005 12:25 am
Have i been dreaming or are the rads from the later 1.4's the same as the 1.7's? I am 99% sure they are the same!!! In which case you might want to mention that!!
Cheers Adam
Post by foggyjames » 02 Aug 2005 12:48 am
VADIS says yes up to a point, but the later part numbers are different...?! I think they're probably the same.
360 ones are dual-core, but without the tapping for a temp sender, for anyone seeking an upgrade.
antiekeradio
Post by antiekeradio » 02 Aug 2005 09:31 am
1.7 radiator is usable for ALL types
at some point; 1.4 got a thinner radiator, that's when the part numbers started to differ.
if you have a thin 1.4 radiator, don't try to use it on a 1.7.
Post by foggyjames » 02 Aug 2005 12:32 pm
This is a man who really knows his stuff :)
Post by 340GLT » 03 Aug 2005 12:01 am
You can put the thicker Rad in a 1.4 though cuz i have done it!! But make sure you get the rubber mounts else it wont fit!!!
Cheers Adam
antiekeradio
Post by antiekeradio » 03 Aug 2005 10:13 am
thicker rad = 1.7 rad = usable for all types.
2L rads can also be used for 1.7 and 1.4, only they don't have the threaded bolt on them for the thermo switch (driving the fan)
Greetings Wouter
Post by classicswede » 11 Aug 2005 09:53 pm
Here is a picture of the rad
Duvel78
Website Admin
Post by Duvel78 » 11 Aug 2005 10:02 pm
Oh it's the early type!
Shame it's in UK... I need a new one for my '84 340...
V3M for life!
Post by classicswede » 11 Aug 2005 10:04 pm
I can get it as far as france no probs. My old man is off there later this year.
