Are you after a shift indicator?classicswede wrote:Thanks Andi but I will let someone else have this,
I cant be bothered with ambiant temp and the econ gauge wont work for me
6 gauge dash
I've already got a shift indicator. I would not mind a oil presure gauge or something unualsual.d3k4y0 wrote:Are you after a shift indicator?classicswede wrote:Thanks Andi but I will let someone else have this,
Come on some has to buy this - Andi needs the money to buy that 240GLT
Simple answer is yes , I did it with some help from Pete Farrell
cables are usually there for ambient temp gauge coiled up under the air filter iirc, then you connect to the temp sender which plugs into drivers side bumper mounting horn ,
econometer requires a length of tube between it and a t piece you need to put in the small pipe to the carb base , there is a instruction leaflet on here somewhere probably in the technical section
Yes, you can fit the gauges to a car that hasn't had them before, but you'll need an ambient temp sensor and wire, and correct tubing for the econo meter. I'm not sure if Andi is including these or not...
Look in the Technical Resources & information section for fitting instructions, which may clear things up
EDIT: Why is everyone beating my postings tonight
