Performance parts cat
Post by filthyjohn » 27 Aug 2007 08:25 am
Would like to say cheers for the spax rear shocks Dai.
Supplied with no problems, and very easy to fit (direct replacement)
:D :D :D
Post by classicswede » 27 Aug 2007 09:01 am
I'm glad you are pleased John.
One quick work of advice with any adjustable damper grease the adjuster to stop moisture getting in and seizing it.
Post by filthyjohn » 27 Aug 2007 12:39 pm
Ah good point, that could have been costly in the long run. I've got them about 12 clicks off minimum now and they're both stiff and supple, very nice indeed with much less roll and bounce. I'll happily recommend them.
Cheers.
Bilbo
Post by Bilbo » 27 Aug 2007 01:46 pm
nice and shiny :D
kaos
Post by kaos » 29 Aug 2007 12:42 am
Dai,
i will be needing some bushes for my rear shocks, how much are they?
Also the front anti roll bar bits have you got a picture of which bit they are ont he front end of the car?
Cheers :)
Post by classicswede » 06 Oct 2007 07:30 pm
Now available 360 twin webber manifold
Image Image Image
£150
It can take quite some time to get so perhaps if a few ppl are interested then a group buy would help.
eskimo_god
Post by eskimo_god » 06 Oct 2007 09:31 pm
do you do 3" front springs and 2.5" rear blocks?
Post by classicswede » 06 Oct 2007 09:36 pm
kaos wrote:Dai,
Cheers :)
Hi Sorry I had not spotte dthis request until now.
I can do the bushes on there own for £16
Post by classicswede » 06 Oct 2007 09:40 pm
eskimo_god wrote:do you do 3" front springs and 2.5" rear blocks?
Hi,
with wanting 3" lowering springs I asume that it is for drifting?
I have them in stock @ £55 a pair, std 2" blocks kits are £25 but if you want 2.5" I can do them for £40 including bolts.
eskimo_god
Post by eskimo_god » 07 Oct 2007 12:04 am
yes it will be for drifting i will order sooner the time still havent found a sond shell yet
RLL
Post by RLL » 07 Oct 2007 08:45 pm
Hi,
Hi Dai,
i´ve PM.ed some requests, have you had time to check out the costs?
/ Risto
"maximum attack"
dalahare
Re: Performance parts cat
Post by dalahare » 12 Oct 2007 03:07 am
classicswede wrote: Anti roll bar link kit for all 340 and early 360's omly £25 set
Front springs any lowering any poundage £55 a pair
Rear alu lowering blocks £25 a pair
Any idea on postage to melbourne, Aus, for all these items? and how much just for the link kit alone, I wanna buy them, but i feel with the ocnversion rate at the moment and postage they may just be a little out of reach.
I've got a 27mm whiteline swaybar coming, it'll be pretty useless fitting it using the clapped out old link bushes, if it turns out to be to exxy, would you be able to provide me with some measurments from the link kit, whiteline said they can provide them if i give them lenght, rod diametre and size of the bushes.
http://www.whiteline.com.au/docs/catalogues/WL_0330.pdf
that has their universal link kits and the volvo swaybar in there (let me know if you don't want that link in here)
Thanks, Rick.
Post by classicswede » 12 Oct 2007 01:23 pm
Hi Rick,
I'll check shipping cost for you. I know it does tend to be expensive. What size blocks do you want? Drop me a PM.
That link is quite interesting
volvo360gls
Post by volvo360gls » 18 Oct 2007 09:59 am
Hi, can you quote me combined figure including postage for the following;
-anti rollbar to body polybushes
-anti roll bar link kit
-front wish bone bushes
-front tie bar bushes
-2inch lowering blocks
-spax adjustabe rear dampers
-3inch front lowering springs
Also what is the lead time on the above? I did pm you in the week but i guess your busy so i thought i'd just add the shopping list here aswell.
Cheers, Rich.
Post by classicswede » 18 Oct 2007 01:21 pm
I've sent you a PM
