Mk1 345 Hotness for sale
Re: Mk1 345 Hotness for sale
It's still not well. 75mph was all I had today. Lunchtime tinkering ahoy...! I think the head may be toast, so a B14.4E swap is on the cards. Luckily I happen to have Nessy on the drive breaking, so it will be a (relatively) painless swap.
Oh, and the drive in to work today was less hilarious than the cruise up the A1 last night, so I think a back-box swap is in order ASAP.
To be fair you'll be doing it a big favour swapping in a 14.4E with Renix... unleaded and electronic ignition ftw!
Chuck the engine in the boot and do the swap at Griz's
If it's going to get done, it'll get done before then, I think. I'd like to keep the original engine if I can. There are two problems... intermittent lumpy running (which is likely to be carb related, but I'm concious that if the spark plug got burnt up...), and the spark plug thread issue. If it's at all questionable, I'd rather replace the engine now while it's relatively easy for me, than leave it for someone else to have a big problem with in 6 months time.
I've just found a huge air leak (on the vacuum side of the breather arrangement - the hoses both sides of the restrictor had big splits in them), which would explain the off-idle hesitancy John reported...and we also had some fun with. There's a bit of tweaking and vacuum leak hunting to be done, but it's a big step in the right direction. It's also allowed me to drop the idle speed below about 1500rpm! The idle speed screw was wound in so far that once that leak was plugged, it was barely running...2-300rpm?
I'm having a great time with it
I'll report back after my drive home on whether that leaning out was blunting the top end, or if there's a further problem.
You should see my 343 Touring with it's new front springs. Shockingly highvolvosneverdie wrote:Highriders rule dude.SteveP wrote:I actually can't believe how high it looks... I think it desperately needs lowering (hides)
Mines about that high I recon.
griffo20022
Did I spot the backend of this at Pod yesterday? Parked near the little fairground area? if so it looked cool as
glad your giving it the TLC it deserves
'90 340 1.4 Vince!
'94 BMW 325i Saloon
'94 BMW 325i Saloon
You certainly did! Myself and Chris hunted high and low for you, but there was no sign...
Hi James.
Thats a nice car you have got yourself there.Well done on finding such a rare beast.
Bt the way,the Leos and rear spoiler from the foggy scrapage scheme are on the car now with new tyres and look great.
Great news, Mark! Are there pictures yet?
I sorted out the exhaust last night. It got a bit late to start posting pics, but I should have an update tonight. I think I'll branch this off into a project thread a bit later.
I think we'll call it a day on this thread. I give you "project thread"! (http://www.volvo300mania.com/forum-uk/v ... =2&t=10298)
