m90 gearbox volvo 940 turbo
i got a m90 manaual gearbox for sale from a 940 turbo it had done 105000 and woz fine went in to all gear no problem give away price £100 no offers
Re: m90 gearbox volvo 940 turbo
What's your location???
west midlands coventry
I've got a pile of them already, but I'll keep an eye on this...
Do you still have the donor car? If not, did you remove the front half of the prop, the crossmember, the shifter and the bracket for the shifter which fits onto the body?
yer i can get all the other bits no problem as the car is still around if it is not gone my the weekend it going on ebay
If anyone desperately needs this I could act on behalf, but I'd not like to hold on for it for long either!
What year was the donor car from? B230FK, or FT? Estate or saloon? I don't suppose the label is still on the box saying exactly which model it is (M90H, M90L, M90L2, etc), is it? Long shot...they normally fell off long ago!
Potentially interested...although I do already have a small mountain of the damn things!
james its from a b230ft Eatate and the sticker is still on the box its a m90h
Ok, thanks for that. I was only looking for the other info to try to work out what it was if the label was missing...so knowing it's an H is all I need, thanks.
Basically, I have people looking for L2 versions in particular...but I have a load of the other ones in stock. If it was an L2, I'd have been pretty keen. As it is...I'll probably have to pass at £100. It's reasonable price, but it's not cheap enough for it to be worth adding to my "pile" (and I'm not joking...!) unless it was an L2.
Good luck with the sale...and let me know if you decide to drop the price.
ok buddy i think i am going to have a ebay week soon i have the turbo for sale off it as well if you know anyone after 1
Hi
i am looking for volvo m90 transmission .
does any one has one ?
thanks
thanks
I have several if Finn has sold his. Where are you located? I have a feeling it's not in the UK, right?
i have still got mine for sale
Dragging up and old thread, but I am a new member. Would someone please share the meaning of the various M90 suffix codes and their relevance to torque handling capacity or whatever of the M90 series please? Or is it a ratio or bellhousing type thing? Thanks.
M90 is a 5 speed fitted to the 900 series, it won't fit a 300 series without extensive work as it is bolted directly to the engine rather than being mounted over the rear axle.
