Collection of big mechanical bits for 300s
Re: Collection of big mechanical bits for 300s
hi iam in Deseret need of some 360 drive shafts 2-4 can you post to tn49hw ? and how much ?
360 front suspension crossmember and a bottom arm?
Both of those items could mean more than one thing. Do you mean the front-most crossmember, to which the ARB is mounted (and the front engine mounts on a 340), or the 'rear-front' one to which the lower arms (the front 'half' of the 'wishbone'), and the steering rack (and the rear engine mounts on a 340) are attached? Similarly, do you need the "straight out from the centre" lower arm, or the radius rod thing (back at 45 degrees)?
I have a radius rod kicking about if you need that and John doesn't have one.
sorry, The rear crossmember, one that the the lower arms, and the steering rack are attached to and the 'lower arms' that go straight out to the wheels NOT the radius arms
Is it possible to get his number as Iam despret for a new diff
Hi havent read through all pages so qplogys if its already been mentioned but have you got a diff, on a gearbox if possible, need one asap
I'll point him towards this thread. I bought two boxes from him, but I'm pretty sure he had at least one more kicking about. I'm talking about 360 boxes now...dunno about 340 stuff. There are different diff ratios for each engine, so you need to make sure you get the right box/diff for your application.
foggyjames wrote:I'll point him towards this thread. I bought two boxes from him, but I'm pretty sure he had at least one more kicking about. I'm talking about 360 boxes now...dunno about 340 stuff. There are different diff ratios for each engine, so you need to make sure you get the right box/diff for your application.
Appreciate it thanks
OK people, apologies for not checking in for a while, I didn't think anyone wanted to buy anything.
I currently have NO spare diffs or gearboxes, a shame as they appear to be in great demand!
I have things like:
Fuel tanks,
Bonnets,
Rear axles,
Wheels (roadwheels and steering wheels),
Steering columns,
Pedal boxes,
And a whole galaxy of interior trim, glass, nuts, bolts, widgets and doo-dahs.
I have things like:
Fuel tanks,
Bonnets,
Rear axles,
Steering columns,
Pedal boxes,
Have you got an early style 340 1.4 fuel tank sender unit? The one that requires the metal ring to hold it in, not the newer plastic twist in one. Thomas...............
Possibly mate, I still have the tank from my 343 so I'll check the sender type and get back to you.
Oh and didn't you want a rear bumper in black? I still have the one with the towbar attached, and it can be seperated.
Sweet cheersfilthyjohn wrote:^^^
I might have done, however i now have a set of bumpers But thanks anyway
Thomas.................
front suspension lower control arm and the crossmember it bolts too?
Possibly mate, you crashed yours like??!??!!!?
