B230 for sale
B230 for sale
Engine for sale removed from a 940 estate and includes the following :
114,000 miles
engine
inlet manifold
afm
exhaust and turbo
lots of wiring!!
clutch dual mass flywheel
ecu
new cambelt
water pump
red metal hard pipe that runs round the block
Basically I removed the engine to put in a 360 not needed due to too many projects
£250 the lot
in dartford
any questions call 07809 408 482
thanks joe
114,000 miles
engine
inlet manifold
afm
exhaust and turbo
lots of wiring!!
ecu
new cambelt
water pump
£250 the lot
in dartford
thanks joe
sammysideways
Re: B230 for sale
ill have it i think. do you have any vids etc of it running?
Re: B230 for sale
no video as i forgot , i was removed from nevs 940 , I can assure you all was well. Car was scrap as the rear axle had gone but he was too lazy to sort it out.
charlieog1243
Re: B230 for sale
any chance of this being sent?
Re: B230 for sale
Hi there yes I would send but it would be at least a pallet and you would have to arrange it. Bump and price drop as need this gone £200 Ono thanks Joe
Re: B230 for sale
Price drop !!!! £120 ono !!!!!
Re: B230 for sale
You'll not find one cheaper than that...
Re: B230 for sale
I take it this has gone by now?
If not i could probably find a home for it in my 240.
Re: B230 for sale
Mag, what you want to look out for is the B23 which I think only existed in some 760s. Basically this engine will "fit" but you need firewall modification to allow space for the dizzy which goes into BIVA territory. Either that or you'll need to do a dizzy conversion. B23 already has a side mounted dizzy like the renault b14 engines
Re: B230 for sale
Can the layshaft from a late 240 with upright dizzy be used to convert a late redblock? Thought that was what Foggy used to bark on about at least, but my redblock Chi is weak.
Re: B230 for sale
The intermediate shaft from a 240 (any 240...)...or...even better...the original 360 engine (
)...can be swapped in. If running on LH, you want to use a rigid dizzy from a later 240 or...a 360 with Renix
The B23ET is a nice engine (fully forged), but specific to 1984 (so rare as hell) and likely to be tired by now anyway. A late FK/FT like this is the best best, honestly. The only slight downer is that it has the wrong flywheel. On the plus side, it has oil squirters. I'd use a later one like this and buy a flywheel, personally. It's a storming deal at that price.
Re: B230 for sale
Ideally just an engine that works, mine has got some annoying Gremlins in the system so thought it would just be easier to ditch the lot and start again. I think you can get shortened Dizzy's and a "crab" cap to avoid the bulkhead cutting now.Speedy88 wrote:Mag, what you want to look out for is the B23 which I think only existed in some 760s. Basically this engine will "fit" but you need firewall modification to allow space for the dizzy which goes into BIVA territory. Either that or you'll need to do a dizzy conversion. B23 already has a side mounted dizzy like the renault b14 engines
Sam340turbo
Re: B230 for sale
hi dude how well do this go in 340 ?? cheers
Re: B230 for sale
would you split this and post parts? if so i might be interested in turbo and manifold a few boost pipes and maybe a few other bits
