breaking next week!
Posted: 23 May 2013 01:02 pm
The volvo has had countless hours spent on in labour, want of new car is swaying sale
Engine:
F7p w/fully rebuilt head(stemseals valve seated and reground ports de-craped, new h/gasket yesterday) + sump and bellhouse. Ready to rock £200
Backwards manifold £80
Williams manifold £100
2.0 bare block w/crank £35
F7p ecu £25
Ported and polished head
Kent 1601 cams £325
Gsxr Bike carbs on home made manifold (could do with tidying up) £185
Solidstate facet fuel pump and fuel pressure regulator £50
Magnacore leads and stupidly expensive plugs £30
Uprated engine and box mounts £35
Mocal oil cooler and sandwitch plate £100
Uprated and rebuilt f7p/r altanator £80
Suspension:
2inch and 3inch lowering blocks £10ea
Rear stiff landrover shocks £15
Dai's drop springs £25
30mm wheelspacers £30
Welded diff £40
2x props £50each
14" vvgc borbet lv4 wheels and good tires £120
2x leos w/caps £40
Interior:
Omp fia spec bucket seats xl + s. £200 or £120 ea
Trs pink harnesses £50
Ripspeed dv720 Flip out dvd £80
Oil press,water temp. Volt gauge with mounting plate and senders £50
Ignition barrel delete and killswitch with
Push button start. £ 50
Momo deepdish steering wheel (snapped inside but still usable £15
Rmd steering wheel. £20
Cheap-o silver moterny wheel £5
Boss allowing keep self cancel+horn £40
Misc:
Towbar+ electrics £60
White 13x7 superlites bit used, some kerbing £250
Hid lights £20
I have a trailer (made by cutting another 340 in half, for transporting wheels/tires around. £400
Roofbox,lockable with rails for gutter mounts. £30
Good con glt spoiler £25
Mega mega rare parts:
Hella grill £80
Louvre £300 w/lid
Hella wind roof defector (ideal for use towing trailer. £100
5door front oem Volvo wind deflectors £25
Engine:
F7p ecu £25
Kent 1601 cams £325
Suspension:
Welded diff £40
2x props £50each
2x leos w/caps £40
Interior:
Misc:
Hid lights £20
Hella grill £80
Louvre £300 w/lid
