Volvo 360 front hump sump ????
olliehood93
Post by olliehood93 »
Hello.
I've a volvo 940 and they have the rear hump sump but we to believe the 360 2.0 non turbo has a front hump sump and as such should bolt onto my engine.
I may be doing an engine swap into something else hence my asking
Re: Volvo 360 front hump sump ????
If this is a technical question then the for sale section is not the best place :)
Anyway yes the 360 sump will fit any B2xx but you also need the oil pump and dipstick as the pickup is in a different place. The bolts might be a little longer as its thicker alloy rather than steel.
I have a 940 Turbo engine in my 360. I'm not entirely sure the oil pump is 100% as powerful as the turbo pump with the oil squirters, but noone reports any issues. Still I am a suspicious Engineer.
