Brand new OS headlight...last call for Ludlow!
Post by foggyjames » 02 Jan 2006 04:04 pm
I'm leaving for Derby tomorrow, so this is your last chance to get me to bring the headlight I have for sale. Post today if you can :)
Post by classicswede » 02 Jan 2006 04:44 pm
Could be interested
Post by foggyjames » 02 Jan 2006 09:22 pm
£20?
Post by classicswede » 02 Jan 2006 09:52 pm
Bring it with you James. I'll twist your arm on adeal :wink:
Thanks
Post by foggyjames » 02 Jan 2006 10:04 pm
Hmm....possibly. :)
Post by SteveP » 17 Jan 2006 04:58 pm
Damn... sold, nevermind!
Post by foggyjames » 17 Jan 2006 06:09 pm
You're already having my new reflectors, right Steve? (in exhange for a pair of used knackered lights, and a seat?). As long as the glass is clean, it's only the reflector which matters, so I don't think you're missing out big-time.
How are you getting on with the oil pan and pump ;) Don't forget the fuel pump cover plate.
Post by SteveP » 17 Jan 2006 06:21 pm
True... thats right...
Hmm oil pan and pump.. well I don't think I'm gonna get a chance to get it off anytime soon. The major factor being that the car is stuck (and wont roll until I get round to undoing a driveshaft) on grass and the only way I managed to jack it up was with a board and ramps that Ali bought along. The thing is gonna have to be gone fairly rapidly :(
Post by foggyjames » 17 Jan 2006 06:32 pm
Well the fuel pump cover should be easy... :D
Take a peek by crawling under it - it might well simply unbolt and clear the crossmember! I think the pump itself is the same as a regular redblock, but the pickup arm is different. It might unbolt...
IIRC the B200 doesn't bolt to the crossmember, so you could remove that (may already have done so to get the PAS gear out?), and then gain unlimited access to the pan...
You never know, it might end up back in your possession at some point!
Post by SteveP » 17 Jan 2006 07:13 pm
I think access to the pan under normal circumstances will be fine, I don't think there wlil be any clearance issues with the crossmember from memory - but I could be wrong. If I can get the car moved from its current position, It'll be off!
Post by foggyjames » 17 Jan 2006 08:16 pm
Name a time and place...I'll be there with a rope and five burly fishermen. Maybe I lied about the last part...
Post by pettaw » 17 Jan 2006 08:50 pm
James I've got an oil pump from my 360 rebuild. I put a brand new one on when I rebuilt the thing but there was nothing wrong with the old one AFAIK.
Post by foggyjames » 17 Jan 2006 08:52 pm
Ooh, cool :) The more the merrier...
Are you coming to Ludlow?
