cheap generator for sale
340ovlov
Post by 340ovlov »
only used this once for pod this year only had 3 tanks of fuel run through it from new its a 2 stroke quiet genny 750w we had 3 phones and 2 lights running of it no problem it has a full tank of fuel ready to use specs as follows with pic this is slightly different in pics but same genny
Specification:
• Max Output: 750 watts
• Continuous Output: 650 watts
• Fitted with a UK 13amp socket
• Engine: 2Hp 2 Stroke
• Fuel Tank Capacity: 4.5 Litres
• Dimensions: 350L x 325W x 380mmH
• Runs for up to 5.8 Hours per tank
• Weight: 22.5Kg
Wolf WP980 Emissions Compliant Generator:
The Wolf WP980 quiet running portable generator provides a maximum 750 Watts output at 230v and will provide a maximum continuous power of 650 Watts. It also has a 12 volt battery charging facility which makes it ideally suited to Caravaners, Campers, Boaters and general leisure activities.
The machine is fitted with 4.5 litre capacity fuel tank and the Generator will operate for up to 6 hours on a full tank. It is fitted with a 2HP 2 Stroke Engine and has a special carburettor and catalytic converter fitted in order to ensure its conformance with the 2007 government standards for emissions.
The Wolf WP980 is fitted with a copper wound alternator. Most of the cheap 2 Stroke Generators on the market today have copper coated aluminium windings. Aluminium wound alternators do not have the same endurance or performance characteristics that copper wound alternators have and this feature alone is very important to the user. Fitting copper wound alternator provides a heavier duty unit and reduces breakdowns.
I'm available on my moblie most days 07960184033 can arrange collection or delivery /meet up some where if distance is a problem
£40 ono
1985 340 1.4 3door
Post by filthyjohn »
WOLF POWER!
Seriously though, £40? That's a reet bargain.
340ovlov
Post by 340ovlov »
open to offers now guys need some money for fuel in the ovlov now i got me diff welded i wana go out and play
1985 340 1.4 3door
Where abouts are you? If you are South somewhere I'm more than tempted for an offer ;)
Post by redline »
I may be interested as well depending on your location
340ovlov
Post by 340ovlov »
i'm just out side of manchester guys
1985 340 1.4 3door
:cry:
Up for coming to the meet next month ;)
340ovlov
Post by 340ovlov »
stuck for cash the only place i'm going is to hennersford raceway for banger racing on the 11th of this month if that helps
1985 340 1.4 3door
Post by redline »
this is getting like the cars on retro rides , all the bargains are lightyears away,
340ovlov
Post by 340ovlov »
**SOLD**
1985 340 1.4 3door
