anyone need any bits off a 1.4 or 1.7 engine?
dez
Post by dez »
got these 2 to rob for any remaining bits after my 16v conversion- the 1.7 has all usual bits to convert a 16v robbed off, plus the inlet manifold is gone, as is the starter- i have the alt still though, still has the dizzy/leads/carb+cable too.
the 1.4 is totally complete except for starter motor(its on in the pic, but i need it), still has the bellhousing on, good clutch/clutch cable/carb/alt/fuel pump/dizzy/etc.
i also have fair condition complete exhausts from manifold to tailpipe for both motors- slight surface rust but totally solid.
can post any bits, and itll all be cheap. let me know if you want anything asap as im running out of space so these 2 lumps will be scrapped pretty soon.
"Ive been loved, Ive been hated, to me its all the same. Embraced- Be a lover or your cursing my name"
-1928 ford model A sedan * ratty VW caddy on 13s * volvo s2 343 F7P, 13x8s-
-DD metalworks-
custom automotive fabrication and welding.
Sliderman
Re: anyone need any bits off a 1.4 or 1.7 engine?
Post by Sliderman »
still got these?
need a 1.7 alternator. postage to derby or i'll collect if you are close.
dez
Post by dez »
yes, i can do either style of alternator- single V-belt of multi-V
PM me with what which you need and ile let you know a price inc. postage.
-DD metalworks-
Sliderman
Post by Sliderman »
brilliant. i'll PM you early next week as im off to london for the weekend with the missus.
fuel pump, a washer for the carb mounting bolts and a throttle cable clip (the one for adjusting tension) if you can manage them too. i'll check on the alt. belt type when i can.
thanks
dez
Post by dez »
yep, can do all of those.
you planning to call in and collect?
-DD metalworks-
Auntie had several
Post by Auntie had several »
I'll take the 1.4 carb if it's good. Can you post?
dez
Post by dez »
Auntie had several wrote:I'll take the 1.4 carb if it's good. Can you post?
yep its definatley good- i did enough miles on it anyway!
postage not a problem, PM for details.
-DD metalworks-
mdw
Post by mdw »
hi i've got a 1.4.
Im after the Plastic t-piece that sits under the air filter housing and connects to top of rocker cover.
Can you help??
dez
Post by dez »
mdw wrote:hi i've got a 1.4.
Can you help??
ahh, ive heard of this fabled T-piece. unfortunately this engine doesn't appear to have it, it has one pipe direct from the filter box to the rocker cover. dunno if its different cos its from a series 2 or something?
so in short no i cant help on that bit!
-DD metalworks-
kds19
Post by kds19 »
how much for 1.7 carb and cylinder head with valves and cam and bits and flywheel?
kev
85 360 GLT drift beast
clutch kicks ahoy!!!!
dez
Post by dez »
complete head £20
flywheel £10
carb £15
£10 to post any/all of it.
DEZ
-DD metalworks-
