Quick tuning advice
Block the oil breather hose that breathes into the hot air intake, it increases exhaust flow and you'll notice an immediate power jump and exhaust sound increase.
1985 - Volvo 360 GLT - V3M downunder! Uprated coils and leafs, Gas shocks, 3A Racing Filter + balls!
2002 - Renault Clio Sport - http://www.ozrenaultsport.com/forum/vie ... php?t=7697
Ok, i set the car up on our college's SuperTracker and the front toe was at 2mm toe in, the manual suggests that it should be at 4mm to in so i pulled it in a bit to get the whole suspension to book figures. It's probably just my imagination but the front end feels a little tighter now
I also removed the hot air pipe and the breather pipes from the air box. I blocked off the resulting holes and then i set about on the interior. I removed my sterio (i dont use it anyway as one of the speakers is blown) and i removed the floor mats. I also pulled out all of the crap that i inadvertently carry around with me on a daily basis and i weighed it all in at just over 6kg's. I also removed the mudflaps and then i gave the thing a good clean and polish.
I have pumped the tyres up to 35f and 37r but i might go up later on in the day.
I'll let you all know how i get on tomorrow evening and i should have a few vids to show you as well
Proud owner of a Crummy Volvo and a Ratty old 205
Ozbrick wrote:Block the oil breather hose that breathes into the hot air intake, it increases exhaust flow and you'll notice an immediate power jump and exhaust sound increase.
You can run the breather hose under the car though or in to a catch can so breather gases and vapor won't go in to the engine.. But you can't block the breather completely...
Or what breather are you talking about, one which is coming under the intake manifold from the black box? Blocking that is a big no no.
And don't bolt on a cone straight on to the MAF.. It will just suck hot air and most likely will give worse results than the stock filter.. Volvo stock filters have quite a large area for stock filters, but the intake piping in the filter box is usually restrictive. Running a larger pipe from the stock box to the front of the car is better in most cases than a cone filter which just adds more noise and sucks hot air.
I've got AEM cone filter because I could'nt fit anything stock in without moving the battery to the trunk. I would've fitted 740 turbo airbox (which is huuuge) but it didn't fit so I had to put a cone filter in..
Our ex-GL Turbo had the stock box with some intake mods and it flowed more than enough, so in most cases the cone filter just adds more noise and it feels more powerfull because of the noise.
Good test is to drive a car shortly without any filter, just a straight pipe or similiar. Then you'll see what's the maximum effect fiddling with the intake filters would be.
Can't say my ricer air filter on the end of the MAF makes any more difference than noise, infact it's beginning to annoy me and I'll probably put the stock induction stuff back.... I doubt I'll be able to feel any difference.
Anyway, this is a carb'd car we're talking about
Small mods to airbox can give you more than you get with freeflow cone + engine will get cleaner air.
1. Get new quality brand air filter
2. Remove that hot/cold flap from front of airbox
3. install air tube from front fog light hole to airbox
Now you have cool CAIRAM-induction kit installed.
Also you could find green panel filter very handy.
Remember that preheating (that hot cold flap and hot air tube from exhaust) is essential in damp and cold weather, especially if you have a carb, it will not run smooth at part throttle if removed completely.
Stick some super unleaded in if no one has mentioned it
Depends what year your motor is - most 300's were optomised for **** - and 95 RON unleaded just doesn't cut itswordfish210 wrote:that makes kack all difference unless you advance the ignition timing to suit, waste of money really.classicswede wrote:Stick some super unleaded in if no one has mentioned it
timing is already set for higher octane fuel anyway - it does make a differenceswordfish210 wrote:that makes kack all difference unless you advance the ignition timing to suit, waste of money really.classicswede wrote:Stick some super unleaded in if no one has mentioned it
Anyway, the track day went fine, i'll start as new thread
