One thing about intake sensor that popped to my mind, be very careful that it won't get any heat soak. For example in my installation radiator was so warm when standing on traffic light that it warmed intake temp sensor pretty much, so mixture did go quite lean and O2 adjustment window is good to keep in 5-15% after initial tuning so it was not enough to compensate.
So where you install it, make sure that material won't get too warm and warm up sensor, makes harder to do tuning also.
I guess you will run ignition and fuel with MS?
My setup was similar to this version from that site: Distributor Based MSnS_Extra Setup : £260
However it needs that Bosch module and coil too, it seem to have VR-input already so you could use renix flywheel and sensor for rpm signal then without hazzle of lm-chip based vr-conditioner that I had to use.
I think pettaw has similar setup like what building from that would be.
Would not get one from ebay as from that site you can get one that is properly done as that guy has good reputation and has made quite lot of those boxes.
Were you going to install wideband O2 too? If not get at least narrowband, without O2 sensor it is engine blowing time almost guaranteed.
Knock sensing would be not too bad idea also as you will be spending lot of time using that loud pedal really well.
But I'm sure you have talked with pettaw and Chris_C about different options and possibilities and what route to go.
When questions come in mind shoot, I believe we few Megasquirters can find some answers to arque about then
