KeithB wrote:Well spotted
Yep, though the carb is not the original r-sport kit carb. It has Weber 32 DAT in it. The cars previous owner was a retired Volvo mechanic who build it. It has also couple of other things added in it, Koni lowering springs/suspension (for leaf springs also) for example etc... Damn shame that the body has gone in so bad shape..foggyjames wrote:Two 360 turbos...damn you!
What is the carb one...an R-Sport 240 kit?
Yeah, I was surprised too that it makes even that much of power with comparatively low boost. Im not also sure what else to that engine in GL has been done, so hard to compare those two cars. GLT leaks a bit thouhg between the exhaust manifold and the turbo so it makes a bit power-loss. Got new selas waiting... GLT has stock LE-Jetronic and extra ECU which controls extra fuel injector placed before intake manifold. Extra ECU is controlled by pressure switch so it gives more gasoline under boost.foggyjames wrote:Koni lowering leaf springs? The actual springs are replacement items? If so, that's awesome.
I'm guessing it can't run much boost with a DIR32, as they're tiny for a (2.0?). What is the MPI engine in the GLT? With carb that small, the ET/FT engine ought to wipe the floor with the carb one!
Great to see two more 360 turbos anyway!
