peugeot fail, volvo win
pyro
Post by pyro » 28 Nov 2010 10:29 am
Need i say any more?
after a night at -10 volvo started first time after being stood for 2-3 weeks, peugeot had to be pushed off the drive to let dad go to work at 5 am :lol: :roll: :cry: :oops:
Ben
* Disclaimer
Mors Principium Est
Re: peugeot fail, volvo win
Post by jtbo » 28 Nov 2010 10:39 am
pyro wrote:Need i say any more?
Ben
What would you except, it is frenchcrap, they don't like from cold, if they start, they will soon throw up all their oil :D
It is small murder to motor each time when motor is started from cold (each cold start is wear to motor equal to 500km of driving at fully warm motor, this was conclusion from research of finnish scientific test lab, VTT is name of that lab), one should use block heater from +5C (or was it +10C?) and colder, but I guess those are only scandinavian spec car's that have one?
pyro
Post by pyro » 28 Nov 2010 10:46 am
innit, it does have an engine preheater on it, ie 6 glow plugs into a coolant hose.
ill let the bitch stew for a bit and threaten it with a big stick then ill try again.
Ben
* Disclaimer
Mors Principium Est
Post by jtbo » 28 Nov 2010 10:59 am
pyro wrote:innit, it does have an engine preheater on it, ie 6 glow plugs into a coolant hose.
Ben
Some have burned their pita with setting up fire under the oilpan, with intention to heat oil before starting up, quite good method to get rid of pita or if that fails, get motor started.
Oh remember to open the bonnet before starting attempt, so your neighbourgs can enjoy from starting attempt to their fullest, that is quite common sight here, remember to look all knowing when looking into engine bay, so they do here, even they are experiencing the flat battery syndrome, often shaking HT leads while looking into engine bay :mrgreen:
If all of above fails, then find big hill, push pita over crest of hill imagining that you can jump in when it starts to move, slip and run after car screaming like a little girl, have seen this one too, quite hilarious, however rather futile if idea behind it is to start pita.
One guy put his pita next to his house, at spring tens of tons ice from roof manage to solve problem quite swiftly and he did not need do anything to achieve this, someone even paid small sum of money to remove metal debris from yard, however in it's original form nobody was not interested from it.
Might not help, but that is what I have seen people do, I haven't experienced such trouble myself, but I do drive mostly diesels and those are fail proof if you keep arctic diesel in tank, if not, add litre of petrol and it does the trick...
pyro
Post by pyro » 28 Nov 2010 11:42 am
im just waiting for vnd to come along and go "ha told you so" :oops: :lol:
gona arm myself with a fan heater/hairdryer :oops: and warm the basterd up
Ben
* Disclaimer
Mors Principium Est
Post by jtbo » 28 Nov 2010 12:01 pm
pyro wrote:im just waiting for vnd to come along and go "ha told you so" :oops: :lol:
Ben
Those probably will not help much unless you somehow restrict outside air to move freely, cardboard etc will help, with heatgun you could get some amount of heat to block.
If it is diesel, then often need to open up fuel filter, warm filter to get goo off and then with petrol + heater need to warm up and made liquid again diesel in pipes etc. Problem with diesel is that it will become goo in cold, with petrol motor things are bit easier, just put start pilot or similar into it while cranking, it should explode to running, or just explode, however 1st one is much more common :lol:
Post by volvosneverdie » 28 Nov 2010 12:06 pm
Ben
They just love surrendering dude.
My dweezil has started without fail even at -8.
Mind you, mines german. Not French. :lol:
pyro
Post by pyro » 28 Nov 2010 12:08 pm
towd landog start first time and it was running on chip fat. just winched it on to the drive way with it as im not goin to be seen in teh street with a hairdryer!
Ben
* Disclaimer
Mors Principium Est
