clear indicators
clear indicators
anyone making them yet? cant find any
Re: clear indicators
We got radicast to make up 20 pairs 4ish years ago. I reckoned they didnt suit so sold mine
http://www.300power.com/forum/index.php?topic=2759.0
A guide to make them yourself. New on this forum, so dunno if there is a guide like this yet.
Worth looking in to tho. The glass is from a lamp.
No, there isn't.
Great first post
Great first post
great post, thanks for the help ill be giving that a go.....ill make a thread of my mishaps
Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
343 DL (W 80)
R.I.P. 77 343 DL vario
343 DL (W 80)
I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
The lad knows his light fittings!magnumpi wrote:I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
volvosneverdie wrote:The lad knows his light fittings!magnumpi wrote:I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
I can obtain said diffuser for you VND if you want to try it.
Write it in your heart.
The code of the West.
Ceilings and partitions i can do
im 300-less old bean.sven360 wrote: I can obtain said diffuser for you VND if you want to try it.
thanks for the offer.
pug already has clear clickers. coz im cool like that.
Indeed you are.I forgot about that.
I'll mebees collect a couple in case you get one later.
You can store 'em in the orange box
Plan.sven360 wrote:Indeed you are.I forgot about that.![]()
Thats why youre in charge of planning.
Watched the vid of the rally 360 man. 1st time id seen it.
You should be running it, not selling it. That is all.
Tango FTW IMO.
The light fitting diffuser idea is just like this the 200 SX boys use the same method too. Shows it's proven to work.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
You my friend... Are absolutely right!magnumpi wrote:I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
I just didnt know the word for it
