Sand blasting alloy?
Posted: 28 Apr 2011 01:36 pm
by theo2468
want to sand blast some alloys I got, but heard if you use to strong sand it will leave dimples in the alloys.
so was wandering if anyone knew the best sand or glass for sandblasting alloy?
Re: Sand blasting alloy?
Posted: 28 Apr 2011 02:03 pm
by L14MNP
Is it just for removing paint? If so then Nitromorse is your friend.
Posted: 28 Apr 2011 02:11 pm
by volvosneverdie
L14MNP wrote:Is it just for removing paint? If so then Nitromorse is your friend.
Add a wire brush and sweat for uber-win.
Posted: 28 Apr 2011 02:12 pm
by theo2468
going to use some nitromors first, but the wheels are heavily corroded so sand blaster to get all that off.
and ive never used the sand blaster before so its abit of fun aswell.
Posted: 28 Apr 2011 02:17 pm
by theo2468
how much nitromors will i need will a litre be enough do you recon?
Posted: 28 Apr 2011 03:02 pm
by L14MNP
Aye, 1 litre tin should be fine. Or whatever size it is for £7/8.
What's the deal then, your dad got a blasting cabinet or do you mean a spot blasting gun? I have a spot blast gun and it's crap TBH.
Posted: 28 Apr 2011 04:01 pm
by Evoman
thought about getting them shot blasted and powder coated?
Posted: 28 Apr 2011 04:17 pm
by theo2468
L14MNP wrote:What's the deal then, your dad got a blasting cabinet or do you mean a spot blasting gun? I have a spot blast gun and it's crap TBH.
I've got a blasting cabinet and a new gun all on the compressor ready to go just need to get some sand/glass
Posted: 28 Apr 2011 11:35 pm
by Hell Driver
I've had alloys sandblasted in the past. I was told it would leave the dimples, but I didn't mind and I certainly wasn't going to sand them all! Quite liked the effect when I saw it and it becomes a softer effect with a few layers of paint. Also makes existing scrapes/dents or later scratches/imperfections less noticeable. It also leaves a mark on steels, but this soon goes with a few layers of paint. It does give a nice key for repainting too! Nice alloys those!
Posted: 29 Apr 2011 09:44 pm
Probably depends on the pressure used, just back it off a bit for softer metal. I would use about 100psi for steel and it leaves a matt rough surface perfect for painting. Say 80psi for Al alloy.
