Volvo 300 Dyno Figures
djntrap
Post by djntrap » 06 May 2012 02:15 pm
Hi guys I thought it might be cool to see everyones dyno results on 1 thread.
I'll go first:
Model: 340 GL Williams F7R
Max power (BHP)@Wheels: 166.7 (5891 RPM)
Max torque (NM)@wheels: 209.3 (4127 RPM)
Top Speed (MPH): 139
Keep it going :)
jon-ovlov
Re: Volvo 300 Dyno Figures
Post by jon-ovlov » 06 May 2012 06:21 pm
Nice! Haven't dyno'd mine yet, but assuming yours is a standard f7r engine (same as mine) it should put out around the same power. Would be cool to get mine on a rolling road though!
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Post by Speedy88 » 06 May 2012 08:36 pm
Never got around to dynoing mine but taking into account the cars I was winning/loosing to and 1/4 mile times I estimated it around the same as you.
Post by jtbo » 09 May 2012 05:54 pm
Is F7R lowly cammed as power comes from such low RPM or is there some work left to do?
I would imagine that well breathing 16 valve should have 6500rpm or more as peak power?
jon-ovlov
Post by jon-ovlov » 09 May 2012 08:08 pm
6500rpm is the F7R's rev limit. Surprisingly low for a 4 cylinder. It's a popular thing to raise the rev limit to 7/7.5K and have a re-map.
Rev engine to 7K
Win at life.
Post by jtbo » 10 May 2012 05:31 am
jon-ovlov wrote:6500rpm is the F7R's rev limit. Surprisingly low for a 4 cylinder. It's a popular thing to raise the rev limit to 7/7.5K and have a re-map.
That is interesting, for me it sounds like if there would be some potential that could be unleashed as it is such, how much re-map and increasing rev limit gains in terms of power?
Intake/exhaust runner length and diameter might need some work to get most from higher rpm of course as those are probably made for lower rpm by factory.
Post by Chris_C » 10 May 2012 09:45 am
The issue you have Jani is the F7R is just a stroked F7P, it'd take a bit of work to get it to rev much past that and not break stuff.
The 1.8's (the P's) are much better at it.
Post by jtbo » 10 May 2012 12:15 pm
So it is bit like redblock with marine crank which makes it bit poor revving and it requires quite bit of work to get most of it.
I knew that there has to be some issue because of such low rpm max power :D
djntrap
Post by djntrap » 10 May 2012 01:53 pm
I have a superchip and am planning a remap but it's on hold as I don't want to get greedy and end up blowing it!
frazeb
Post by frazeb » 10 May 2012 03:04 pm
good results. any idea on what a f7p puts out compared to the r i was thinking around 135 but thats just a guess
