It was p******* fuel all over itself inside.. I've had the carb off and in bits today, piece of cake - Tighten blatantly obviously loose parts, blow through jets, remove inspect bits n bobs..
I thought it was running cold too, the temp wire was a bad connection.
I'm surprised it ran at all with the amount of fuel pishing out of... emulsifier tube end cap.. ?
Tappets are fine, first ones I haven't touched.
Gearshift next.. I'll see if will tighten+adjust but I'm thinking this gearbox has a misplaced shim or something, so I'll have to mod the gate.. and it's only 6:24
