driftking89
Post
by driftking89 » 23 Jul 2013 04:59 pm
Hi there as some of you where aware i had slight issue getting hold of the rear mounts for a 340 i Have recently solved this problem by going to a company called "robush" they are based in grundisburgh near woodbridge in suffolk
They are not exactly the same as the originals but however much better in the design they are stronger and seem more up to the job the larger ones to the rear you will have to use a m12 as originals are a m10 so slightly bigger bolts problem solved in all with a little bit of discount for all four around £100 including tax mans contribution so if anyone needs some i should be able to help solve the problem
Volvo 340 2.0 Supercharged drift wagon
Volvo 850R 2.3 Turbo
Toyota Celica 2.0 Import
Post
by Speedy88 » 23 Jul 2013 08:37 pm
Thanks for the tip-off dude
Post
by bogbasic » 23 Jul 2013 09:20 pm
Wicked work. Can they help with 360 ones??
driftking89
Post
by driftking89 » 24 Jul 2013 04:14 pm
should be able to you will need to measure them up and give them a call unless the rears are the same on both models but pretty sure there not
Post
by Ride_on » 26 Jul 2013 01:13 am
360 ones are completely different (only 2), plus there is the aluminium bracket that corrodes.
driftking89
Post
by driftking89 » 26 Jul 2013 12:27 pm
A picture and some measurements and ill see what I can do
mac
Post
by mac » 27 Jul 2013 11:45 am
Yes Robush carry a huge range of isolation mountings - in the past I've looked at the range they do for suspending equipment like commercial air con units (where the weight is likely to be similar to a transmission unit).
One note of caution - do ensure that the final "hanging level" of the g/box/diff is exactly the same as OE. The propshaft alignment MUST be maintained exactly!. Any induced angles on the prop couplings will rapidly cause failure of the rubber inserts. (even worn engine mounts will do this). Wear, and any separation in the rubber joints will introduce vibration and can easily cause stress failure of the bell housing/clutch shaft casing.
Keep up the good work!
Mac.
driftking89
Post
by driftking89 » 29 Jul 2013 05:32 pm
yea kept the same hight thank god for washers lol very minor differnce a thou difference is barely enough to worry got it half mounted ill put a pic up in a while
annoyed with my parts suppliers as my rear slave cylinders are wrong so cant put the brakes together :@
Ive done new lines for the hydrolic hand brake undersealed where the box ect is so i dont have to ruin it
