Spain Classic Raid
Bor
Spain Classic Raid
Post by Bor » 04 Oct 2017 11:18 am
The entry has been closed and the list of entrants published.
135 teams from a dozen countries.
Cars range from the hardcore R4s and Pandas to a Porsche 944 and Delta HF. In between Citroens, Mercedes, BMWs, Seats, Fiats, Peugeots, Volkswagens, Audis etc. with most Japanese brands represented by a 4x4.
Oddly enough nó British entrants and only one Brit make car; a LandRover Disco.
We again have our #65 and are listed with a DAF 77 :lol: variomatic and all sm4
Bor
Re: Spain Classic Raid
Post by Bor » 05 Oct 2017 04:55 pm
The skid plate:
Her smooth bottom with absobtion damper is obvious as is her being higher on the legs.
360beast
Post by 360beast » 05 Oct 2017 06:19 pm
Good luck, hope all goes well and the daf comes out relatively unscathed.
Bor
Post by Bor » 06 Oct 2017 12:25 pm
Any techies on board?
Am sorting out how to fit the vacuum-buffer with one-way valve in the downshift side of the EMVK.
I want to make sure I have understood it right,
Here is the kit I have prepared:
Bor
Post by Bor » 07 Oct 2017 12:05 pm
Fitted, see the wire for the ´caravan gear´ too:
360beast
Post by 360beast » 07 Oct 2017 06:55 pm
What do you mean by caravan gear?
benji1985
Post by benji1985 » 07 Oct 2017 07:49 pm
360beast wrote:What do you mean by caravan gear?
low hold
360beast
Post by 360beast » 07 Oct 2017 07:50 pm
low hold
Ta, thought it might be something to do with a lower ratio.
Post by SteveP » 08 Oct 2017 11:21 am
Good luck! Liking the mods :)
Bor
Post by Bor » 08 Oct 2017 12:22 pm
SteveP wrote:Good luck! Liking the mods :)
We´ve also dropped in a hotter cam and swapped the paper air filter for a K&N one.
The only thing left to do to the engine is switch the wires of ignition timing sensor to give a mite more advance.
For the rest we took only a few bits off. All in all about 50 kilos. Not earth shattering, but 50 kilos off and 10 hp more, propelled with a lower ratio does make for a way more lively car.
Oh and we moved the spare wheel from the front to behind the passenger seat. Again not changing the nature of he thing but still a difference.
I have resisted the urge to change the seats. The standard ones do not offer any support but they do offer ample change of position and we have experienced that this is more important than side support. Ditto spingy versus rigid. We will after all be doing up to 8 hours of dirt road driving with a 45 y.o. car design.
Lastly we run way more pressure in the front tires and thát doés change the nature of the car; it does away with the heavy understeer: With the rest of the changes it adds up to neutral steering which can be seduced into oversteering.
The suspension set up makes the car a joy to drive over speed bumps and undulating dirt roads. She jumps smoothly. Hence her name ´Jolly Jumper´.
p.s. just been out for a long cycling ride and my son has swapped the standard claxon for a ´beep-beep´ air horn. Will check in a moment.
Post by SteveP » 08 Oct 2017 02:40 pm
Any pics of the car overall? It looks pretty tough with them tyres and mudguard! :)
Bor
Post by Bor » 08 Oct 2017 05:28 pm
SteveP wrote:Any pics of the car overall? It looks pretty tough with them tyres and mudguard! :)
Yes, but as work in progress and not suitable for office or family only
https://myalbum.com/photo/iaFjao8K6WW8/1k0.jpg
Bor
Post by Bor » 18 Oct 2017 04:06 pm
low hold
More like a mid hold :wink:
It is between the mountain switch and the normal.
Basically a ´sports´ setting.
Got the extra 12V socket in and swapped the ashtray for a rev counter. Looks nicely uncluttered.
Counting down now; we´re off Friday at sunrise.
Post by SteveP » 19 Oct 2017 08:06 pm
Bor wrote:Yes, but as work in progress and not suitable for office or family only
What car? :lol: :lol: Good luck!
