apology
apology
sorry to anyone who has tried to contact me over the past month but due to personal circumstances I have not been at home much and have been extremely busy. This applies especialy to hugh, If you still need this prop contact me asap
Thanks
Iain
Thanks
Iain
Don't worry about the prop Iain...I sorted Hugh out with one, although given his reputation, he'll soon need another
gits..
no worries husky, as said, james sorted me out with one..
i do now need a rocker cover and gasket thou
Haha...what on earth did you do to the rocker cover?!
dunno. its warped and pissing oil out the side (onto my exhaust manifold, causing lots of smoke. spectacular, but not necessarily good
Exactly what Nessy is doing...caused by a clogged breather I bet.
Not neccessarily - if you overtighten the bolts holding the rocker cover on you can warp it.
I did that to my 345 after adjusting the tappets - I thought (in the absense of a torque wrench) that tightening them until v tight would do it. WRONG - major oil leak, which I thought was a knackered gasket so that got replaced. Hmm, leak still there..........
If you remove the rocker cover you might be able to straighten it with judicious use of a hammer - it worked for me!!
