Just Introducing Myself :)
Hi guys,
Just wanted to say hello and to introduce myself. I've been a reader of this forum for a few months now but I've only just signed up. I'm also a member of a few other volvo forums so you might already recognise the sign in name (I recognise a few from various forums).
For those that don't know me, I'm already a volvo owner but not a 300 I'm afraid. I've got a "slightly" modified S40 and I'm after a cheap 300 1.4 to use as a fun daily driver.
The only problem is, the modifying bug has well and turely gotten hold of me and I can see my "cheap sensible daily driver" getting some 16v treatment etc.....
I'll post up pics and specs of my S40 if anyone is interesed (and dosen't offend anyone!)
Cheers, Andy P
Cheers, Andy P
Here's a pic of the car -
And the current spec -
Car:
1998 Volvo S40 2.0T SE (B4204T 160bhp std spec) M56 Gearbox
Engine:
Turbotecnics Garret T380e Hybrid turbo (internal gate)
Siemens Deka 630cc Injectors
Walbro GSS342 255lph fuel pump
Volvo B4204S n/a cams
JT-tuning 3" turbo back (decat, no centre box and freeflow rear "silencer")
Group A Cosworth K&N air filter
Custom filter heatshield
Front mount intercooler (510bhp capable)
Custom 2.5" aluminium intercooler pipework
IPD plug wires
Denzo iridium plugs (heat range
Custom 3” Hard inlet pipe
Mopar big end bearing
Mopar main bearings
HKS SSQV
SPM Forged Rods
T4 lower compression pistons with Valve pockets machined
Water / Methanol Injection
SW Autos modified T5 manifold for 4 cylinders
ARP Bolts
Mikalor Clamps
Transmission:
Custom Clutch made by SACHS with S60R plate and higher clamping pressure
Quaife ATB LSD
Wheels/Suspension:
Lenzo Zeon 17" wheels
Yokohama Parada specII 215/40/17
KW V1 Adjustable Coilovers
Lower Rear arms modified to allow further lowering
Whiteline Rear ARB
Evo 3 Rear Strut brace
Phase 2 rear droplinks
Lower H – Brace
Front Strut Brace
Brakes:
AP 330mm x 28mm grooved Discs
KAD aluminium centre hats
KAD Billet aluminium 6 pot callipers
Ferodo DS2500 brake pads
Tarox braided brake lines
DOT 5.1 Fluid
Exterior mods:
Phase 2 twin beam headlights
Clear turn lights
Audi RS4 front bumper
"Eggcrate" Grille (matte black)
Side trim removed
Light smoke tints
Body colour skirts/ rear spats
Misc:
Fibreglass pillar gauge pod, trimmed in OEM cloth
Apexi auto turbo timer
Boost gauge
Exhaust Temperature gauge
Oil Temperature gauge
Oil pressure gauge
Sequential shift light
Battery relocated to boot
Mapped by Marco of MTE. Currently only running 75% DC on the boost control solenoid and up to 6.5k rpm (map unfinished). Guesstimated current power @ 375-380bhp.
Cheers, Andy P
Car:
Engine:
IPD plug wires
Mopar main bearings
HKS SSQV
SPM Forged Rods
ARP Bolts
Mikalor Clamps
Transmission:
Quaife ATB LSD
Wheels/Suspension:
Whiteline Rear ARB
Lower H – Brace
Front Strut Brace
Brakes:
DOT 5.1 Fluid
Exterior mods:
Clear turn lights
Side trim removed
Light smoke tints
Misc:
Boost gauge
Oil pressure gauge
Cheers, Andy P
Lol, its not shy I suppose!
Its the reason I'd like to have the 1.4 as a 2nd car rather than the 1.7 - to try and keep insurance, tax and fuel costs down to a minimum!
Hopefully as well, if I reduce my mileage and exclude commuting on the S40 insurance I'll get it down a bit. Every little helps - especially at 22 with only 2 NCB!
Thanks for the comments!
Andy P
Andy P
Very nice spec. The thing must go very well. Do you have problems putting the power down through the front wheels??
I'd go with a 1.4 but I imagine you have the bug and will not be able to leave it stock and end with sticking in a 16 valver or 1.7 turbo!
Surprisingly its not all that bad! The turbo is massive and dosen't boost until higher up the rev range but the way its mapped is very linier. Torque steer can be a bit of a handful though! Its fine if the road surface is good because of the equal length shafts and decent suspension setup - but uk roads are never good!
Its an exciting drive thats for sure!
Andy P
Andy P
