The great Volvo 300 replacement debate
Hmmm, I wouldn't agree with the heavy clutch either. Both mine are fairly light, even compared to modern cars.
Comfort-wise I notice the difference most in the gearchange which is a bit notchy compared to other vehicles, the heavy steering on my non-PAS GLi, and the wind noise from the sunroof in the GLT. Other than that, I'd say comfort is one of the big factors in a 300's favour
New shocks can make a world of difference, maybe that's one route to follow? And maybe some new seats from a low-mileage car?
I would happily exhange my PAS for your air con any time Maybe it just needs refilling, kitted out with a fresh filter/drier?
Andys A/C is awesome, really really cold, but then he did just pour pound notes into the top of the filler
This is purely subjective of course, but my Volvo-engined 360s are a lot quieter than my old 343, at least below 100 mph. The wind noise in the GLT (sunroof) is pretty bad though. No new seals available from Volvo for that anymore
Isn't there some kind of manifold solenoid valve to boost the idle revs when the air con is on?hatch360 wrote:definately needs refilling but with the low revs im not to sure its worth it
Not sure about that, but in my car that problem has been solved with raising idle revs. AC on idle is ~950rpm and ac off idle is about 1100-1200rpmtrabitom99 wrote:Isn't there some kind of manifold solenoid valve to boost the idle revs when the air con is on?hatch360 wrote:definately needs refilling but with the low revs im not to sure its worth it
1999 Volvo S80 T6 Quiet long distance cruiser.
1990 Volvo 360 GLi Waiting inspiration.
1989 Toyota Land Cruiser For days when wellies aren't enough inside the car.
1987 Volvo 360 GLi Being restored.
1986 Volvo 740 Turbo Sold, but not forgotten.
See here: http://www.volvo300mania.com/forum-uk/v ... 6&start=15trabitom99 wrote:No new seals available from Volvo for that anymore
for new seals. They've cut down road noise a lot, but not as much as I'd like!
If someone says that clutch is heavy and so is the steering. They should try driving a Massey-Ferguson 165 from i'm not sure was it from the 60' or the 70' without powersteering. There is heavy steering and clutch for you...
Had a look in my green book last night. Apparently on B200E models, there's a solenoid valve in the throttle body which bypasses the idle speed screw when the air con is turned on, thus raising the revs. It says, the revs should actually be higher when the compressor switches on.Tourinki wrote:Not sure about that, but in my car that problem has been solved with raising idle revs. AC on idle is ~950rpm and ac off idle is about 1100-1200rpmtrabitom99 wrote:Isn't there some kind of manifold solenoid valve to boost the idle revs when the air con is on?
Maybe it doesn't work so well in practice ...
That looks good ... Has anyone tried those seals on a sunroof as well?Ronnie wrote: See here: http://www.volvo300mania.com/forum-uk/v ... 6&start=15
Tourinki wrote:They should try driving a Massey-Ferguson 165 from i'm not sure was it from the 60' or the 70' without powersteering. There is heavy steering and clutch for you...
Looks good too
