Injection to Carbs
Injection to Carbs
Evening chaps...
Right, well I've bought Rich's (Volvo360GLS) B230K and Weber 40's along with my K cam to go in my 360 which is injection. Just wondering if anyone knows what I'd need for this... I assume a FI > Carb fuel pressure regulator to step the fuel pressure down and the fuel pump blanking plate from the B200E fitted to the 230K. Can anyone else see any other complexities?
Also, are 40's big enough for such a capacity?
Try and get some K+N's or similar rather than those sock thingies.
Caused many an underbonnet malady as Bilbo knows.
The neighbours are goin' to love you on a cold morning
Write it in your heart.
The code of the West.
When I was looking at the same conversion I'd decided that 40s should be ok but they'd be at their limits. 45s would be much better, but obviously the price jump is quite substantial and may not justify the potential benefits.
Carl
Rover SD1 Vitesse (and no Volvos )
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
for that engine 40's ought to be fine, the 230fk has the pretty appalling 631 head which makes it interference and has combustion chambers milled into the pistons iirc so I'd imagine the webers won't quite run out of puff reaching full potential. Should still see a nice 140 ish bhp from the engine though.
still, I know you got the engine seriously seriously cheeeep! as I know what price I turned it down at when I realised it was a 230fk (only on basis that I couldn't really justify driving that far for an engine which isn't compatible with my b230fb)
Not exactly sure on how much lift makes each 2.3l lump interference and tbh I don't really care either (H-cam on the way )
With the carb conversion once the fuel pump is sorted I would just try and scrounge some jets similar to a ford 2.3 as there is probably loads of info on them and the 8v's won't be hugely different.
Yeah, it should work out ok then with the 40's it seems! So does anyone know what the stock carb fuel pump is like, is it like a B14 one in the side of the block? I assume I can use the blanking plate from my 360 and run the electric fuel pump still
I've the same plan, and I want to tune the carbs with a wideband lambda sensor. A LC1 from innovate motorsports + a RPM module is 'cheap' and effective.
http://www.innovatemotorsports.com/products/lc1.php
For the pump, I'll run a continuous electric fuel pump from Carter in the US... High flow capacity and very low pressure. No FPR is needed. Tomorrow I look for a reference to you
40s will be fine IMO
Greetz from Spain !!
A friend of mine once told me that diffence between H and K is just few precent and racey idle. So i would go for the one which i can find easier and cheaper.Nikdev wrote:40 are a bit small on the b200, but it will be fine as it don't rev that much. But why a K cam? Get a h-cam
1999 Volvo S80 T6 Quiet long distance cruiser.
1990 Volvo 360 GLi Waiting inspiration.
1989 Toyota Land Cruiser For days when wellies aren't enough inside the car.
1987 Volvo 360 GLi Being restored.
1986 Volvo 740 Turbo Sold, but not forgotten.
