Exhausted!
Posted: 03 May 2008 02:19 am
by Cloud
Ok, I getting confused trying to look for the exhaust parts i need. Does anyone have a pic of the 360 GLT 85' exhaust parts? or better yet can someone tell me exactly what i need? I see some for GLE GLEi etc...but are these early or later ones and so forth?
Posted: 03 May 2008 07:05 pm
by Ronnie
My 360GLT is registered 1985, but has an '84 spec and has the newer type exhaust fitted - HOWEVER, this was probably a modification sometime in it's life.
The older, smaller, straight through type of backbox is reputedly better flowing than the more modern doubled-back-on-itself design, but it has a narrower diameter tube on it and so may need some kind of adaptor to fit if you have a later type system on.
Posted: 05 May 2008 10:48 pm
by filthyjohn
Measure the bits Cloud, there's about a 2-3mm difference in diameter iirc.
Posted: 06 May 2008 08:38 am
by hatch360
Ronnie wrote:The older, smaller, straight through type of backbox is reputedly better flowing than the more modern doubled-back-on-itself design, but it has a narrower diameter tube on it and so may need some kind of adaptor to fit if you have a later type system on.
If the old ones less restrictive, why did they change it??
Posted: 06 May 2008 05:48 pm
by filthyjohn
The same reason they changed to FWD in the 90s. (because they're silly).
That later backbox looks like some kind of hideous satanic bugle.
Posted: 06 May 2008 05:58 pm
by Jason B
yup, the exhaust was crafted to rob us of torquezz
