My current 1988 340 has a 4 speed box and my previous 1989 one had a 5 speed box, am I correct in thinking the 5 speed only came into action from 1989? Its also awkward to get into reverse gear, is that a common 340 trait?
J
4 Speed/5 Speed Gearbox?
No, the 5 speed was available much earlier. I can't remember the exact year for a 340, but it's at least 1985, I think. It's a pretty easy (and direct) swap, if you fancy an upgrade...
Reverse...can be tricky. Some examples are worse than others. Changing the gearbox oil can help, but make sure you're confident in doing this before setting off. There's a technique to making it easier: try 2nd then 1st before going for reverse. Checking the clutch cable is a good suggestion. You may simply need to engage it slowly - reverse is without syncromesh on these cars.
