Carb to injection on a 360
Hi everyone, just wondering how hard it would be to convert from carb to injection on a 360, and is there much point? is it possible to just pull of the injection parts from a 360 and stick it on the carb'd one or are there other more important differences?
Matt
Matt
1987 Volvo 340 1.7
Wouldn't bother to be honest, the 360 injection system is rubbish, and you'd have to run new fuel lines as injection runs at a much higher pressure.
If you really wanted to conver to injection the best bet to look would be megasquirt.
Well.. rubbish is quite harsh statement.. This 360 has LE-JetSteveP wrote:Wouldn't bother to be honest, the 360 injection system is rubbish, and you'd have to run new fuel lines as injection runs at a much higher pressure.
http://www.garaget.org/video/0n2izis9rshw
http://www.garaget.org/video/mmnkkb9uti0a
Doesn't seem to be a limiting factor..
But yeah I would also install the MS if you are converting from carb.
I don't imagine it has just LE-Jet, though. Anything with a 'flappy paddle' airflow meter is very old technology now, and it shows.
For the prices of a mega squirt and the manifold etc....it MIGHT give a decent amount of power with a good map, I don't know how much people are getting from the mega squirt on a standard engine, it would be nice to know?
B Volvo 360 GLT - 2.0i 52k
Andy's 360 (B200E, K cam, MSnS-E) made about 122bhp on the dyno, IIRC.
That seems to be bit low compared to my experiences, but used engines are rather different (all wear and such).foggyjames wrote:Andy's 360 (B200E, K cam, MSnS-E) made about 122bhp on the dyno, IIRC.
I doubt that such differences come from throttle butterfly modding, even some website told it would be big factor. Anyway I had such mod too.
It's the same dyno which measured my 360 (same spec, except twin carbs instead of the EFI manifold) at 140bhp...and I believe it also measured Andy's car at pretty much exactly the right power originally. The engine was rebuilt about 3 years ago, IIRC.
The numbers are a little lower than I expected (perhaps 125-128, say?), but having the full "elephants trunk" intake in place won't be helping...I believe Andy said he was measuring vacuum at WOT at high RPM...indicating that the intake is causing airflow problems.
If I were to do this (and I'm not ruling it out yet, just need more pennies which are currently being spent on other cars) then I would think bunging in a hotter cam (K or H) and then running megasquirt on ITB's or something equally noisy
- that ought to make about 130bhp ish I'd have thought. But then I'd also not bother with the B200 and stick the hotter cam on a 230fb with a 531 head
- then you'd be up to the 150bhp ish with a few other mods I'd think... mmm, getting tempted back into working on the volvo again
You'll do better than that. Mine made 140bhp on 40s (with 32mm chokes) a K cam and a stock exhaust...not exactly a wild setup. Stick 40mm ITBs and a header and exhaust on it, wind it out to 7k or so with a suitable cam (H may well do it), and I think you'll be knocking on the door of 2-ton with the B200.
That basic formula is known to make over 200bhp when B230-based, and because the head flows better, proportionately, B200s usually make almost as much peak power as B230s...witness B200FT vs B230FT...10bhp in it.
Ah, there is difference, mine gets bit more pressure than when engine is off, that is on road of course. My intake was build so that air was forced into intake manifold, when overtaking that little extra was felt, but of course it was not much of 'boost', just enough to keep it from falling into vacuum.foggyjames wrote:...I believe Andy said he was measuring vacuum at WOT at high RPM...indicating that the intake is causing airflow problems.
Nice figures
Iam expecting 130hp @ fly from my 2.0 renault engine bearing in mind its like new!
cold air feed
2.5" exhaust no cat should see it imo, foggy be affraid very affraid when the turbo's on wooop
should see 172hp boosted @ 5psi
200hp at 8psi
based on calcualtions of course. lmao
cold air feed
200hp at 8psi
Volvo 340
1988
