What you plan to leave out to make room for turbo?
Nah, V6 has two cylinders too little, but then again V8 won't fit without massive modifying, so I guess that boring 4 banger is still best solution for cheap go, for show, well they have fit Merlin motor into car before, that would make nice almost bolt on for 300, yes?
Driver just needs new location, in a boot that is
BTW, I believe V6 from Safrane should be quite easy fit (some had 180ish hp?), mounts are different, but I think swap from PRV solves that, maybe some other parts too is needed, I remember reading from such swap in the making quite some time ago, we need Fuse to rescue again, he should have all data from that too as he has from probably every engine swap that has been done or planned to be done for 340/360
Was it always getrag box in 264/265?
Citroen ZX Dturbo -97 -daily-
