whats ti worth then.
kaos
Post by kaos » 15 Mar 2009 05:04 pm
Right im end of my tether.
volvo 340.
3 door shell.
registered as a 1.8 with 2 seats!
no mot or tax.
rebuilt 1.8 16v F7P engine.
it has been driven arround 5 miles tops.
full stainless exhaust system from the manifold back. 2.5" with 4" can on the back.
new rear shocks.
custom dash.
all original seats are avalible
now doesnt like starting so probably a change the fly wheel and it works or find a better startermotor solution.
bad news:
white wing on passenger side doesnt fit nicely, and hole cut from inner wing that i havent welded yet ( only major rust i had to remove)
surface rust now in places.
brakes need to be changed, and hand brake main cable swapped as it no longer works ( new cables on the rear end)
lots of paperwork incluing dealer service history. and £1000's spent!
Would i be wrong to ask £1000 for it?
Re: whats ti worth then.
Post by volvosneverdie » 15 Mar 2009 07:02 pm
dude, its no doubt worth that, and all the other £ youve spent on it, but nothings selling at the minute is it?
everyones struggling to move ANYTHING. Even for pennies.
bad time to be moving a high value car man.
can you not hang on to it til the summer?
people love buying fast cars when the suns out.
kaos
Post by kaos » 15 Mar 2009 07:13 pm
i can keep it forever, but im sick of spending £30 here £30 there on starter motors that dont work, who knows i could change the flywheel to the spare i have and well it might carry on with the same problem! or it might not, but i think ive come to my tethers end!
Post by volvosneverdie » 15 Mar 2009 07:16 pm
Shame dude.
But totally your call like.
Hope someone takes it on. Bet its a screamer.
Jason B
Post by Jason B » 15 Mar 2009 07:54 pm
kaos wrote:i can keep it forever, but im sick of spending £30 here £30 there on starter motors that dont work, who knows i could change the flywheel to the spare i have and well it might carry on with the same problem! or it might not, but i think ive come to my tethers end!
I don't see why you are having so much trouble though? - surely you've asked adam etc what they use, as far as I'm aware the two 16v 300's I've seen were fine... would I be out of line if I said that maybe you've not built the thing quite right...
sven360
Post by sven360 » 15 Mar 2009 08:10 pm
Jason B wrote:... would I be out of line
In this instance possibly not but as general rule of thumb,yes. :lol:
Write it in your heart.
The code of the West.
Jason B
Post by Jason B » 15 Mar 2009 08:18 pm
true, been out of line since I bought that bit of french tin... at least its galvanised... means it doesn't get too rusty whilst its waiting for me to repair it :lol:
kaos
Post by kaos » 15 Mar 2009 08:58 pm
No you wouldnt, But the thing has driven round the block with no problems. it has driven with no problems what so ever. untill now.
ive spoken to adam, woodoo etc, and it all points to wrong starter motors, and ive used volvo 1.7 ones i even went otu n brought a renault 19 one again to try, and well thats doing the same as everythign else, screaming away,
Ive had one chap suggest that its because the minute the starter motor is bolted on its engaged as there -2mm starters on a different set up to usual, i expect if i changed to the volvo flywheel, and volvo starter it would run fine. Its a lot of effort for something that might not even work.
If some one was to come and say ive got these starters you can try. and one work and continuously work with no problem, maybe i would be happy. but im getting sick of it, the car hasnt seen any decent driving since i took it of the road in may last year!
its taken me long enough, to get this far, and to be let down by this problem
Post by 340GLT » 15 Mar 2009 09:15 pm
Trust me i ensure you changing the flywheel wont help, unless yours is damage. The teeth count is identical on them. So either your flywheel is damaged or its wrong starter. Without being anywhere near trhe car i cant be any more help than that mate.
i told you what starters i run. You have to remember on a fresh built engine compression is high so you really need a strong battery and a decent starter. You tried a fully charged battery a known good starter and a jump start aswell?
kaos
Post by kaos » 15 Mar 2009 09:28 pm
fully chargerd battery on the volvo starter has worked fine. on its own, but after 2 start ups it will conk out.
Ive put pics up of the flywheel, and its fine, no teeth missing etc, ive got a chap willing to send me starter motors at cost price! which is great, but if they dont work i really am at my tethers end.
If i could say take it to a garage and them piss arround and that i'd be happy as feck! if they got it to stay working etc!
Post by volvosneverdie » 15 Mar 2009 09:32 pm
i'll give you 100 english pounds for it. cash.
if you can deliver it.
and if its got good wheels on.
And a full tank of petrol.
in fact no, 75.
Will you take it in £5 a monthly installments?
kaos
Post by kaos » 15 Mar 2009 09:37 pm
£100 monthly installments,
4 tyres + the 4 on the car
Post by volvosneverdie » 15 Mar 2009 10:07 pm
kaos wrote:£100 monthly installments,
Too rich for my blood cowboy.
Ive only got 75 in the piigy jar. :lol:
Post by jtbo » 15 Mar 2009 10:22 pm
Have you tried additional ground to block, have you tried shimming starter?
If it does not spin, just is not turning engine, it could be brushes too, but more commonly electrical connections and bad / too low capasity ground cable. Of course it could be power cable trouble too.
My V8 starter tends to get bit hot under exhaust manifold so when hot it is barely turning even with new battery, also engine has more compression than original so that adds to it, but it starts still without problem.
kaos
Post by kaos » 15 Mar 2009 10:52 pm
jani,
this is from cold!
It has an additional engine earth 2 AWG!
i can try shimming the starter and its a simple cost for me to get done!
i mgiht look into a shim during the week.
