Hi All
ive been trying to get some lowering block U bolts.. ect
but in Australia where a bit limited to european car
ecsapically 360's so would turning around the leafs on the rear
be a good idea??
good idea?
Re: good idea?
Hmmm... it could possibly be done, though it's something that I wouldn't try myself.
Tell you what, why don't you PM Dai (ClassicSwede), I think he's a busy chap but he might be able to get you a set of lowering blocks sent over, if you don't mind waiting for them awhile, it would be fairly cheap by sea freight.
I'm going to get a set sent over once I can afford it. This is why I've not modded my 360 yet, ordinary off-the-shelf parts are dear enough without going for performance ones.
I assume all these leaf-sprung Falcodore Ute owners can get lowering blocks, so it might be worth seeing who supplies those and seeing if they can be adapted..
Mods: custom paint fade
New Cylinder head.
Auxilary cooling fan.
Vario Vents FTW
G8 4 DRFTN etc....
New Cylinder head.
Vario Vents FTW
G8 4 DRFTN etc....
Re: good idea?
turning around won't be good, every bump the bottom of leafspring will hit the chassis
you don't need U-bolts since the leafs are mounted on a flat plate next to the axle beam. m10x*** (depending on lowering) and minimum 8.8grade steel bolts is what you need.
