Electric wiper glass motor
Hello,
I'm looking for a electric wiper glass motor. I prefer the left model ref : 3287649, but it's may be possible to fix mine with the right model. Ref : 3287650
Thx
Thx
Re: Electric wiper glass motor
Hi charly.
I this the motor for thr front window screne or the back screne or the front head lights.
I have all three.
I have all three.
Sorry I dont know the english name. The motor to open and close the glass of the front doors. Rear glass are moving manualy on my car. May be more easy with a picture :
NS (nearside / LH) Front electric window motor. (to move the doorglass up and down)
viewtopic.php?f=8&t=13646&p=165534&hili ... or#p165534
^^^^ This may help: Range Rover.
Gear teeth / des dents d'engrenage ?
Volvo 10T / Range Rover 8T
Hello, you should be able to open it carefully and then get inside the electric motor box to clean the commutator which might help.
Or should that be 'commutateur' for Monsieur Macplaxton, I jest, not that I am renowned for being a farceur, which isn't as rude as it might sound - think farce, folks
Hi charly.
Sorry, i do not have a front door motor. Hope you get it fixed.
The Range Rover parts a not more easy to found here, I'm afraid.macplaxton wrote: ^^^^ This may help: Range Rover.
Yes, I do that twice. Each time it works 2 or 3 days, no more..bogbasic wrote:Hello, you should be able to open it carefully and then get inside the electric motor box to clean the commutator which might help.
MCHUDD wrote: Sorry, i do not have a front door motor.
Hello, try something like this...
http://www.ebay.co.uk/sch/i.html?_odkw= ... r&_sacat=0
... but beware that they come in at least two sizes (!) so go for one of the early ones where the connection block on the side is relatively small compared to the metal canister and I think you will be OK with swapping the gearboxes over and a bit of soldering to swap the connectors, etc.
... edited this a few times to refine the search - it should be showing the right ones now, but get in soon or someone else might be tempted to get a few spares while they're still plentiful.
It's possible I may have what you're looking for - somewhere.
Definitely buried in the depths of hell but I've just bought a 360 saloon with a broken offside window motor, so I'd likely be digging them out to find one to fix my 360.
If I find the nearside one, I'll let you know.
1984 Volvo 360 GLE Saloon
1987 Volvo 340 1.7GL
Additionally -
1966 Ford MK1 Cortina
1971 Hillman Imp
1984 Renault 18 GTD
Additionally -
1971 Hillman Imp
1984 Renault 18 GTD
It's ok I got a good one from a 360 ! Left and right are different, I had to switch the motor :
thanks everybody for help.
Should you get stuck again, the motors are used in quite a few cars and are made by a German company Brose.
If the gearbox is worn, cleaning the motor wont help. if the spindle gear wobbles more than around 0.2mm (gap between gear and body) by hand its needs replaced, or maybe something can be changed but probably needs heavy duty tooling.
