360 halfshaft bolts
samueljon
360 halfshaft bolts
Post by samueljon » 21 Jun 2011 09:37 am
has anyone got any 360 halfshaft bolts laying about, or know the best place to get them from?
jon-ovlov
Re: 360 halfshaft bolts
Post by jon-ovlov » 21 Jun 2011 10:43 am
Surely some higher tensile bolts of the same size would do the job?
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
samueljon
Post by samueljon » 21 Jun 2011 02:41 pm
ye they would mate, if anyone knows the diameter/ strength etc they are please shout
hate allen heads sm2
jon-ovlov
Post by jon-ovlov » 21 Jun 2011 03:52 pm
Mine were a bugger to get off. Was sooo worried about rounding them. Luckily didn't.
I'd go highest strength available. I assume you haven't got any old bolts to measure up. They going on your car?
Rev engine to 7K
Win at life.
samueljon
Post by samueljon » 21 Jun 2011 04:27 pm
ye there for mine, as you said they are just a pain to do bolts would be so much easier!
Post by MCHUDD » 21 Jun 2011 04:39 pm
There is a special tool that take them of when they are rounded.
Donn't know what its called but a decent machanic would be able to tell you.
Those hex jobs are a real bitch.
Cheers Mark. sm4
samueljon
Post by samueljon » 22 Jun 2011 08:33 am
hi mate, i can take them out, i just cant get them tight enough, normal bolts would be alot easier thats all
driftlover
Post by driftlover » 07 Jul 2011 03:59 pm
the only problem with using hex heads as your half shaft bolts is you cant really get a socket on as the gaitor is in the way
i just put some new caphead (allen key) and lock tighted them in as i had a issue with my exhaust vibrating 1 side loose as it was hitting the half shaft when i get back ill hook you up the same, also i bought a britool extension 6mm allen key makes life easier, you just got to use the right tools and loads of wd40 about 5-10 before you take em off!!!
if that dont help you let me know i will come and do it for you!!!
cheers luke
driftlover
Post by driftlover » 07 Jul 2011 04:05 pm
oh and they are 8mm caphead by 25 or 30 not to sure on length when im home ill post it so it stays on forum forever :)
