360 halfshaft bolts
Posted: 21 Jun 2011 09:37 am
by samueljon
has anyone got any 360 halfshaft bolts laying about, or know the best place to get them from?
Re: 360 halfshaft bolts
Posted: 21 Jun 2011 10:43 am
by jon-ovlov
Surely some higher tensile bolts of the same size would do the job?
Posted: 21 Jun 2011 02:41 pm
by samueljon
ye they would mate, if anyone knows the diameter/ strength etc they are please shout
hate allen heads
Posted: 21 Jun 2011 03:52 pm
by jon-ovlov
Mine were a bugger to get off. Was sooo worried about rounding them. Luckily didn't.
I'd go highest strength available. I assume you haven't got any old bolts to measure up. They going on your car?
Posted: 21 Jun 2011 04:27 pm
by samueljon
ye there for mine, as you said they are just a pain to do bolts would be so much easier!
Posted: 21 Jun 2011 04:39 pm
by MCHUDD
There is a special tool that take them of when they are rounded.
Donn't know what its called but a decent machanic would be able to tell you.
Those hex jobs are a real bitch.
Posted: 22 Jun 2011 08:33 am
by samueljon
hi mate, i can take them out, i just cant get them tight enough, normal bolts would be alot easier thats all
Posted: 07 Jul 2011 03:59 pm
by driftlover
the only problem with using hex heads as your half shaft bolts is you cant really get a socket on as the gaitor is in the way
i just put some new caphead (allen key) and lock tighted them in as i had a issue with my exhaust vibrating 1 side loose as it was hitting the half shaft when i get back ill hook you up the same, also i bought a britool extension 6mm allen key makes life easier, you just got to use the right tools and loads of wd40 about 5-10 before you take em off!!!
if that dont help you let me know i will come and do it for you!!!
cheers luke
Posted: 07 Jul 2011 04:05 pm
by driftlover
oh and they are 8mm caphead by 25 or 30 not to sure on length when im home ill post it so it stays on forum forever
