360 drive shaft
matt~driver
360 drive shaft
Post by matt~driver » 05 Sep 2014 06:43 pm
hi im after a 360 2.0ltr rear half shaft or drive shaft depending what you call it. mine has broke so could really need one
matt~driver
Re: 360 drive shaft
Post by matt~driver » 07 Nov 2014 11:16 pm
still need a half shaft it there's any out there
Re: 360 drive shaft
Post by bogbasic » 08 Nov 2014 04:49 pm
Mine broke only a couple of years ago and the garage I took it to (or rather they towed it in) just ordered a new one so unless they are unobtainable, maybe one of the main parts suppliers can still supply them?
Re: 360 drive shaft
Post by Ride_on » 09 Nov 2014 01:19 pm
I would be interested to know where/how did it break?
I have a spare refurbed carb 360 half shaft I'm prepared to part with, I spent a fair bit of effort on it so want £50, delivery should be less than £10 for UK.
Refurbed halfshafts
Re: 360 drive shaft
Post by bogbasic » 09 Nov 2014 02:20 pm
Don't tell me the carb ones are different from the injection ones....
thododd
Re: 360 drive shaft
Post by thododd » 09 Nov 2014 03:02 pm
viewtopic.php?f=53&t=15958
according to findings published in this thread ... yes
Re: 360 drive shaft
Post by Ride_on » 09 Nov 2014 04:29 pm
They are interchangeable AFAIK, but I have an injection pair on the way, will post more details.
What broke???? I need to know.
Re: 360 drive shaft
Post by bogbasic » 10 Nov 2014 12:36 am
Man, those are evil half-shafts - we used to do that with smoke detectors (not one to be tried at home).
matt~driver
Re: 360 drive shaft
Post by matt~driver » 13 Dec 2014 09:42 pm
sorry for late reply still need one
it was knocking a bit but thought it was a gearbox bush so after setting of to work changed to 2nd gear put foot down a bit and no drive it striped the splines on the hub side cv and on the shaft itself seemed to be a bit rusty so that probably contributed to it.
mines a 2ltr on carb so gle as think the glt was injection. I was under the impression that the shaft flanges were the same on both but were bigger than any of the other Renault engines.
Re: 360 drive shaft
Post by Ride_on » 14 Dec 2014 01:56 am
They are generally interchangeable and the same except for a gasket on older ones and the injection ones have bigger and longer splines and a shaft with bumps. 360 carb is the same as 340. You could try and find the injection ones but they are rare, I have a spare ungasketed carb type.
I'm not sure about gasket types being interchangeable.
