Im after the following,
will collect within reasonable distance, failing that they will need posting:
pair of two door window trims (the plastic part that runs around the external windows edge. complete in black would be ideal. wi
lower window trim for above. the part that goes between the window and the door.
pair of rear 4door handles (the ones without the locks)
I require both drivers side, and passenger side door catches. this is the part that bolts to the b panel with the "D" loop ion it. with bolts if available.
firewall hooks for bonnet engagement. the part that the bonnet rollers engauge into. I require the pair.
please pm me if you have the items available.
or contact me direct @ seb1275@hotmail.co.uk
thanks.
madseb.
