rear drums
rear drums
I need rear drum parts for my 81 1.4 340 not much left of the ones I have . or bits to convert to discs, or advice please.
Re: rear drums
Which bits so on you need? All parts are available on eBay.
Re: rear drums
mine has been stood for 17 years backplates and drums are ruined and I cant find replacements. new or good used.
Re: rear drums
http://www.ebay.co.uk/itm/2x-A-B-S-Brak ... SwMgdXzAOy
The drum measurements look almost right but would need double checking.
http://www.ebay.co.uk/itm/REAR-BRAKE-SH ... SwZcZZ2iLh
http://www.ebay.co.uk/itm/NEW-REAR-WHEE ... SwA3dYkzY7
http://www.ebay.co.uk/itm/BRAKE-HOSE-RE ... SwNSxVBwFd
You only need one flexi hose for the rear axle.
I doubt you will get a replacement back plate new so you will have to get them off a car being broken or make new ones.
Re: rear drums
mine are 203 mm and will either have to have back plates made or convert to discs (around £500) but that what you get buying a 1981 wreck .
Re: rear drums
also parts can be got by bornbuiltbeauties.com and classicswead.com
Re: rear drums
There you go
https://m.ebay.co.uk/itm/2x-A-B-S-Brake ... iid%253A16
203mm drums.
I paid more than that for my 228mm so you won't get them much cheaper.
As for the back plates Dai might have a 340 in for breaking or Bogbasic on here knows of two 300 series local to him being scrapped he might be willing to get the back plates for you if you ask nicely wether they fit though is another question as they might have the 228mm drums.
203mm drums.
Re: rear drums
thanks for that , ABS is a brand name and not anti-lock ? , may be a stupid question but I am new to these. As for the back plates I would be very grateful and willing to compensate as necessary , meanwhile back at the rust monster work continues with the engine strip . thanks for the trouble taken.
Re: rear drums
I have a pair of back plates for the 1.4 rear drums.
Need a good wire brush up but other than that they are fine, will need to double check
Ben
Ben
Re: rear drums
that would be great because a disk conversion was going to hit my build budget HARD.
Re: rear drums
ABS is the brand not what we know it as
Re: rear drums
thank you for putting me straight on that , when my build is finished I will have a lot of parts left and they will be available to the forum .
Re: rear drums
These are for a 360 and not for a 340.
Re: rear drums
Let me know if you want these back plates, i am sure i have a pair but need to find some time to look for themcleggy wrote:that would be great because a disk conversion was going to hit my build budget HARD.
Ben
Re: rear drums
I would very much like the back plates.
