Page 1 of 4
13" steel wheels / any 300 wheels
Posted: 04 Dec 2006 01:50 pm
by Sam340
As above I am looking to buy a couple of sets of steel / alloy wheels that will fit a 300 preferably 13".
Just need them to use for drifting so I can put all my tyres on before i go to an event.
Currently I have only got 1 set of 13inchers.
Anything you have / wanna get rid of let me know
Cheers!
Posted: 04 Dec 2006 02:44 pm
by redline
I have four 13" rims from a corsa if you want them ( same pcd but slightly bigger centre bore to the volvo ) two have got good 165/70/R 13 tyres on them , £20.00 the lot , I am in Milton Keynes , p.m. me if your interested
Posted: 04 Dec 2006 02:58 pm
by Sam340
Am definately interested, do only two of the wheels have tyres......need to work out when im next gonna be up your way!!
Posted: 04 Dec 2006 09:36 pm
by A M R
look on ebay mate. should be able to get some for pennies
Posted: 05 Dec 2006 08:55 am
by redline
two have very good tyres , the other two are certainly not legal
( I suppose that dosen't really matter for drifting though )
Posted: 05 Dec 2006 10:23 pm
by volvo360gle/340turbo
i hav a pile of 300 wheels, if you are intrested? how many do you need?
Andrew
Posted: 05 Dec 2006 10:27 pm
by Sam340
3 - 4 pairs would probably do it.
......where are you based though?
Posted: 05 Dec 2006 10:32 pm
by V6 Man
redline wrote:I have four 13" rims from a corsa if you want them ( same pcd but slightly bigger centre bore to the volvo ) two have got good 165/70/R 13 tyres on them , £20.00 the lot , I am in Milton Keynes , p.m. me if your interested
Not to try and ruin your sale Mick, but I'd be wary of using rims thatdo not have the correct hub sizing as you are putting all the strain onto the (only 4) wheel bolts. For ordinary use this may be ok, but when subjected to the extra torsional forces of drifting I feel it may be a recipe for disaster.
Posted: 05 Dec 2006 11:51 pm
by redline
I have one thing to say to you my good man ,
Spigot rings
lol
Posted: 06 Dec 2006 05:48 am
by tigersport
I have a set of said 13 inch steel rims, including the black spare (well its painted black) with Michelin Energy Tyres on them, with the treds being about 2.5mm on 2 and 4mm on the other 2, with the spare coming in at 3mm (but that's a Firestone). Even have the wheel trim covers for covering the bolts (totally useless for your purpose but well you know).
Posted: 06 Dec 2006 01:25 pm
by dalahare
If your bolts are tightened down correctly it won't matter if the centre hub is the right size or not, all the strain is always taken by the bolts and the pressure that they put between the wheel and the hub. correct size hub or spigot rings are usufull for getting the wheel centred though.
Posted: 06 Dec 2006 07:41 pm
i am based in northern ireland! but 3 pairs should be no probs!
Posted: 06 Dec 2006 09:13 pm
by Sam340
Ahh northern ireland could be a problem... god knows how much it would cost to send wheels from there!
Thanks anyway but I reckon it will start to cost a bit with postage etc
Tigersport - how much you wanting for your wheels? again postage could be a bit ££
Posted: 07 Dec 2006 05:43 pm
by sven360
Posted: 07 Dec 2006 08:54 pm
I know a number of guys that have wheels with the wrong centre bore (and no spigot rings) that use them for ralling and other hard useage and have not had a problem.
The main strain in drifting is just starting to get the wheels spinning after that the strain is reduced. In fairness drifting is not by a long way the most brutal copetition use you can put a car to.
