Speedo Cable
Speedo Cable
Need a new speedo cable - Part deleted, none in Sweden even...
Anyone got one knocking about - preferably new? Or know where I can get one?
Found ya one.... I'll buy the next one I see.
http://cgi.ebay.com.au/VOLVO-340-360-BR ... dZViewItem
1985 B200E 360GLT Hatch
Just in case anyone from the LHD world is reading this, I found this Italian website which appears to offer speedo cables for all LHD 300s back to 1976:
http://www.ricambiflex.it/html_eng/prod ... TER+CABLES
Untested though ...
Untested though ...
They do seem to take into account the Smiths / VDO differences. What I don't know is if there are other differences (such as engine type?) which aren't considered there ...
I never understood for example why Sweden should get their own part number for a Smiths speedo cable ...
Do you remember which part no you asked for Jos? I could do with either one of these:Jos360 wrote:In Holland, i informed about the speedo cable a couple of weeks ago (at the Volvo dealer) and they could order new ones from Volvo for about €35.
3205601-2 (VDO LHD) or
3205802-6 (VDO LHD Sweden)
but I'd always thought they were NLA ...
If anyone's desperate, I have the LHD equivalent, part no 3298995-6 ...Chesh740R wrote:I have a brand new Speedo Cable for the RHD Smiths Instruments I believe according to Vadis if its off interest to anyone.
I can still get three kinds of speedo cables locally (second source, not original Volvo, probably Ricambiflex then) - all are 15 EUR -
1976 - 08/1981 Smiths, length 135 cm, with 2.5 x 2.5 mm ends
09/1981 - 08/1984 Smiths, length 140 cm lower end is 3 x 3 mm
09/1984 - 1991 VDO length 134 cm, with 2.5 x 2.5 mm ends
They also mention a 09/1984 - 1991 Yazaki type which is not available. Whatever that is, then... Smiths is the one with a plastic clip, and VDO is the one with a bayonet i.e. twist 1/4 turn and it'll come off.
But they're all for LHD models so probably won't help you much...
