Im after x2 17mm nuts for the nearside brake calliper on a 1988 Volvo 340DL as mine are almost rounded off!
Jus
17mm Nuts For Nearside Brake Calliper?
Hi Justin,
I assume you mean the (17mm spanner size) bolts that hold the caliper carrier to the strut base.
You may (if you're very, very, lucky) still be able to get them from a Volvo dealer - the part no.is 3293749 and two are req'd each side.
If you cannot get them from Volvo try a fixings or engineering suppliers you would need to ask for:- 35x12x1.75 Flange head HT bolts Grade 8.8. The factory originals are thread self locking - with replacements you would need to use a locking compound. (Loctite 241 would be the correct grade).
ATB- Mac
ATB- Mac
