air intake pipe...
Posted: 20 Jan 2009 06:32 pm
by pyro
hi all I'm after a 70mm (2 3/4) inside diameter intake pipe for the land rover, I believe this is the same size as the 360 inlet pipe, the one that runs over the radiator but i could be wrong! (cant check cos im at uni and the 360 is at home! :()
anyone know a supplier or has some lying about?! need about 2m i believe.
thanks
ben
Re: air intake pipe...
Posted: 23 Jan 2009 10:01 pm
by nekto
if you mean pipe, which is goes over radiator and intended to pass hot air from exhaust to inlet, then this pipe has 50mm inside size.
