windscreen and sunroof.
Hi guys, shortly im going to require a new windscreen in good condition, and a sun roof.
both of mine are covered in weld and grind splatter. my seals pretty good from memory so they shouldnt be needed. but if any one has a windscreen and can deliver it and help fit it (ideal!) it would be gratefull.
theres a bti of time yet as cars suposed to be goign to paint end of the month.
Re: windscreen and sunroof.
i have sunroof but can't deliver
Surely you will want the windscreen after paint then?
yep hence the not needed right away. but soon.340GLT wrote:Surely you will want the windscreen after paint then?
I can probably help with at least the windscreen. I take it the S/R will be a glass 340 one?
If you're after an OEM metal sunroof panel, I have one with very minimal rust - probably as good as you'll ever find now anyway.
if its a glass one ur after then i have one
steve p intrested, got a pic and price in mind?
others yeh glass 340 sun roof, and windscreen mine are caked in weld splat
If you know of anyone who can change a roof skin striaght swap FOC, find me a solid roof, and you can have my glass sun roof. But that's a lot of work. I dont want a sunroof lol
If they're in working condition they're nice to have in summer ... The problem is - usually they're not in working condition
Remember: you can replace the seal with one from a VW Beetle / Golf Mk1, see this post:
http://www.volvo300mania.com/forum-uk/v ... e&start=15
and it's not particularly expensive ...
mine works spot on. just the glass is covered in weld and grind splatter
same as my windscreen
It's the metal ones which are a problem. There's not exactly anything to go wrong with the glass ones...except them leaking!
Come and cut the roof of my gl. I also have all the glass.
Ian.
Ian.
