Needed for the new friend in my life.
B14 Battery clamping bar.
Mac
Battery clamp.
Battery clamp.
Re: Battery clamp.
Hi Mac.
I have one from a 360 if that is any good.
Re: Battery clamp.
Hi Mark,
Thanks for the offer - I think I've found one (only think at present).
I'm not really sure if they are the same (the B172 and B14 are the same part (3105753)) but on some Vadis screens the same no. is used for the B200 but on others it's a different no. (3560001). They certainly look very different on Vadis (that doesn't mean a lot though).
Certainly the B200 battery and tray are much larger. If "anybody out there" could compare a B14/B17 and a B200 side by side that would be very usefull.
All the best - Mac.
All the best - Mac.
Re: Battery clamp.
Yes they're very different. (B14.4E -89 vs. B200E -86) On the B14 it's a bent piece of steel maybe 5 cm wide, with one bolt holding it in. On the B200 it's more like one whole edge of a rectangular frame, with one bolt at each corner (two in total) holding it in place.
Volvo 340DL Variomatic -89
Volvo 360GLT -86
Volvo 360GLT -86
Re: Battery clamp.
Is it not relatively easy to just make your own one? It's just a blade of metal that bolts on as far as I know?
Re: Battery clamp.
Hi Mac
Just found a 1.4 battery clamp bar in my pile of spares.
Give me a shout if you are still stuck.
