Hi huys,
Which thermostat housing have people been using? i have been thinking about using the 1.7 housing as it would make life easier in plumbing in the hoses.
F7r conversion Thermostat housing
Re: F7r conversion Thermostat housing
If you can get hold of one off a R19 it goes the same way as the original so its lets you use the 1.7 water pipes. The clio one goes the other way.
this is a R19 one, which is ideal as fittings for the coolant temp senders are both in the housing on the R19
Cheers i will try and get one tomorrow!
