Performance parts cat
Re: Performance parts cat
Post by classicswede »
Auntie had several wrote:Dai, posted you a cheque weeks ago and heard/received nothing. Can you tell me what's going on? Tried to text but heard nothing either. Cheque was for 2" lowering blocks and 3" lowered front springs........Jonny
HI Jonny,
not see the cheque as yet. My dad has been away for the past two weeks so it could have got mixed up with his post. He'll be going through it all tonight so I'll let you know if it is there. We spoke quite a while ago if I remeber correctly. I think you were going to have think on which to go for 2 or 3" drop.
If it is there I'll get you bits off to you asap.
Auntie had several
Post by Auntie had several »
Thanks Dai, I hope the cheque is there somewhere - do let me know. I have decided to go for 3" drop on front coils with a level of stiffness that doesn't shatter teeth but keeps the front end planted during corners. Will go for poly bushes later.
Thanks Dai. Look forward to hearing from you asap.
Hi Jonny,
Cheque was with my old mans post. I'll the bits sent to you tomorrow.
Auntie had several
perfect - thanks Dai. Look forward to understeer elimination!
Cutler
Post by Cutler »
Stuff arrived today, everything looks ok!
Thanks!
Sideways @ flat 2 the mat forever!
Rally-gious!
ross_striker
Post by ross_striker »
Hi Classsicswede
Please answer my pm's,
Ross
sps
Post by sps »
Hi Dai
Are the 1.7 engine mounts ok to use on a 1.8 clio engine? i know i used the 1.7 ones before so i'm guessing they would be ok just wanting to check. Think i checked a year odd ago and they were not ready - also after a 1 1/2" rear lowering block kit.
Thanks
Shane
wixsy
Post by wixsy »
Do you do a 3" lowering block kit for the 360 :)
mat 91
Post by mat 91 »
hey im after some front lowering springs and stiffer shocks
for a 340 1.4
thanks mat
Hi Mat,
if you have not done so already drop me a PM
Rear leaf spring bushes now available @ £38 a set
Post by foggyjames »
Poly, or rubber, Dai? These seem to go creaky quite often, so that's some good news, either way.
As you would expect from me they are in poly with stainless sleeves so a lifetime replacment.
Excellent - thanks for the update.
nomead
Post by nomead »
I seem to get creaking from the left rear corner when doing some enthusiastic cornering to the right. Turning the same way (or with even more determination) to the left won't produce any excess noises from the right side though.
What is included in the rear spring bushing set? Looking at the VADIS rear suspension diagram there seems to be a larger rubber bushing (3101000) inside both spring ends, and then a thinner, longer rubber bush (3100556) that's inside the spring shackle. Are any of the mounting bolts and nuts included?
Volvo 340DL Variomatic -89
Volvo 360GLT -86
